I’m not sure if there’s an easy way to fix this, but I just did it to myself.
If a user opens too many tabs of a Discourse site, they will get rate limited without an explanation.
It took me a few minutes to figure out, and after I figured it out, I checked the logs and can see that there’s a user in Europe who is getting rate limited from the same problem at the moment, probably not knowing why.
Would it be possible to make the UI check for a rate limiting message? And then if that tab is getting rate limited, it could show a message saying, “Please close some of your forum tabs because that’s why you’re getting rate limited.” Otherwise, there’s no indication about why the site doesn’t work.
Another idea is to add a line to the message something like this:
Slow down, you're making too many requests.
Please retry again in 5 seconds.
Error code: user_10_secs_limit.
If you have the forum open in many browser tabs open at once, close the tabs and the site will work again.
Edit: another idea is that if the frontend gets a rate-limiting message, that tab could print a message to the screen that it’s inactive, and then stop pinging the backend with that tab.
