Using ember within Docker install
Hello,
I am using the docker installation of discourse, but cant seem to interact with ember. I would like to add some ember addons to the project, but no ember commands work (I get the error ember: No such file or directory). I am sure I am missing something here.
Thank you!
You should search for “plugin development.”
More specifically, I think the problem is that you’re trying to use Ember’s CLI tool, which Discourse doesn’t use as far as I know.
Follow @pfaffman’s suggestion to get started, and let us know if you run into problems :slight_smile:
…and I just realized that this is a duplicate of:
