Using keyboard shortcuts to navigate between replies causes topic to be "stuck"
When moving down a topic using J, it gets to a point where you can’t navigate any further using the key. Even if I try to move up (K) and move down, I still cannot move below that specific reply.
I believe this reply is the last of the loaded replies and the keyboard shortcuts doesn’t trigger the loading of the next batch of replies?
Also, scrolling up/down when encountering this does not work. Oddly enough, you can’t load the next batch even if you try and scroll down - no loading spinner, nothing, even the bottom reply isn’t the last one.
I can reproduce this consistently on an internal site and it seems to happen when the height of the last topic fits nicely within the screen.
Going to put a pri-medium on this for the team to look at.
This issue seems to be fixed now @tgxworld ?
I don’t think anything was done here. I can still reproduce it but not in a reliable way.
I sometimes got stuck in a topic too. But it was not because of using a keyboard shortcut. I don’t use keyboard shortcuts to navigate on my tablet.
But I also have no reliable repro, so I’m not sure if this adds anything helpful.
The PR above addresses this issue.
