Vanilla Importer (vanilla.rb) - Error while importing users
Hello,
I am trying to migrate from vanilla into discourse. I am trying the import steps outlined here.
The import job errors out always while importing users (see screenshot attached). When I rerun the script the error repeats for a different user leading me to believe that the issue is not specific to a specific user record but instead a problem with the the db schema or a timeout of some sort (as evidenced by the line in the error dump - “Javascript was terminated either by timeout or explicitly”)
I tried combing thru vanilla.rb to check for timeout values that I can maybe increase but I couldn’t find any such references. Thoughts?
Bump. Anyone having a similar issue? I couldn’t find any topics within the meta that addressed a similar issue.
Does that user have a bio by any chances?
I dont believe they do. But what I have noticed is that, every time the import job runs, it fails on a different user but with the same error, which leads me to believe that the issue might not be with a specific user but with the timeout not being high enough (my export file from vanilla is pretty huge ~1.2GB).
What are the other errors?
Seems to be the same as the previous one.
" ‘eval_unsafe’: Javascript was terminated (either by timeout or explicity)"
bump, anyone have a similar issue?
According to the stack trace it’s timing out when “cooking” the bio of that user. Are you sure that your users don’t have any bio?
I am experiencing the same issue. No none of my users have bio’s.
Looks like a memory issue, i restarted the docker and it worked
Same here, issue went away after rebooting the machine and restarting docker. Have a couple of REDIS issues now (seems unrelated) but this timeout was solved by “turnin’ it off and on again” :slight_smile:
