Vari errori dai log di docker e problema HTTPS
Hello,
if I type in docker logs discourse I get the following output:
run-parts: executing /etc/runit/1.d/00-ensure-links
run-parts: executing /etc/runit/1.d/00-fix-var-logs
run-parts: executing /etc/runit/1.d/anacron
run-parts: executing /etc/runit/1.d/cleanup-pids
Cleaning stale PID files
run-parts: executing /etc/runit/1.d/copy-env
Started runsvdir, PID is 39
ok: run: redis: (pid 52) 0s
ok: run: postgres: (pid 50) 0s
rsyslogd: command 'KLogPermitNonKernelFacility' is currently not permitted - did you already set it via a RainerScript command (v6+ config)? [v8.16.0 try http://www.rsyslog.com/e/2222 ]
rsyslogd: imklog: cannot open kernel log (/proc/kmsg): Operation not permitted.
rsyslogd: activation of module imklog failed [v8.16.0 try http://www.rsyslog.com/e/2145 ]
rsyslogd: Could not open output pipe '/dev/xconsole':: No such file or directory [v8.16.0 try http://www.rsyslog.com/e/2039 ]
supervisor pid: 51 unicorn pid: 84
and I don’t know how to fix it. I did find out that KLogPermitNonKernelFacility is a bug but not for the rest. It is basically the standard config but with jwilder reverse proxy.
discourse.yml:
## this is the all-in-one, standalone Discourse Docker container template
## After making changes to this file, you MUST rebuild
## BE *VERY* CAREFUL WHEN EDITING!
## YAML FILES ARE SUPER SUPER SENSITIVE TO MISTAKES IN WHITESPACE OR ALIGNMENT!
## visit http://www.yamllint.com/ to validate this file as needed
templates:
  #- "templates/web.socketed.template.yml"
  #- "templates/web.ssl.template.yml"
  #- "templates/web.letsencrypt.ssl.template.yml"
## which TCP/IP ports should this container expose?
## If you want Discourse to share a port with another webserver like Apache or nginx,
## see https://meta.discourse.org/t/17247 for details
expose:
  - "127.0.0.1:3030:80"
docker_args:
  - "--network=nginx-proxy"
params:
  db_shared_buffers: "4096MB"
  #db_work_mem: "40MB"
  #version: tests-passed
env:
  LANG: en_US.UTF-8
  UNICORN_WORKERS: 8
  ## Required. Discourse will not work with a bare IP number.
  DISCOURSE_HOSTNAME: forum.domain.tld
  ## Uncomment if you want the container to be started with the same
  ## hostname (-h option) as specified above (default "$hostname-$config")
  #DOCKER_USE_HOSTNAME: true
  DISCOURSE_DEVELOPER_EMAILS: 'admin@domain.tld'
  ## TODO: The SMTP mail server used to validate new accounts and send notifications
  # SMTP ADDRESS, username, and password are required
  # WARNING the char '#' in SMTP password can cause problems!
  DISCOURSE_SMTP_ADDRESS: mail.domain.tld
  DISCOURSE_SMTP_PORT: 587
  DISCOURSE_SMTP_USER_NAME: discourse@domain.tld
  DISCOURSE_SMTP_PASSWORD: "supersecretpassword"
  DISCOURSE_SMTP_ENABLE_START_TLS: true           # (optional, default true)
  ## If you added the Lets Encrypt template, uncomment below to get a free SSL certificate
  #LETSENCRYPT_ACCOUNT_EMAIL: me@example.com
  ## The http or https CDN address for this Discourse instance (configured to pull)
  ## see https://meta.discourse.org/t/14857 for details
  ## Nginx Proxy
  VIRTUAL_HOST: forum.domain.tld
  VIRTUAL_PORT: 80
  LETSENCRYPT_HOST: forum.domain.tld
  LETSENCRYPT_EMAIL: admin@domain.tld
volumes:
  - volume:
      host: /opt/discourse/data/
      guest: /shared
  - volume:
      host: /opt/discourse/logs
      guest: /var/log
## Plugins go here
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
run:
  #- exec: rails r "SiteSetting.notification_email='discourse@domain.tld'"
  - replace:
      filename: /etc/nginx/conf.d/discourse.conf
      to: |
        listen 80;
          # issue with ip and the nginx proxy
          real_ip_header X-Forwarded-For;
          set_real_ip_from 172.20.0.0/16;
Also everything is loaded through https except:
http://forum.domain.tld/uploads/default/optimized/1X/_129430568242d1b7f853bb13ebea28b3f6af4e7_2_32x32.png
it shows in Chrome console. If I click on the link it will load it through https. It is the default Discourse logo.
Is force_https enabled?
No, it is currently not.
Well it should be if your site is served over HTTPS, even if you aren’t using the built-in implementation and take care of it using a reverse proxy.
Otherwise how would Discourse know to rewrite the URLs for HTTPS?
Ok, l’ho abilitato. Il problema persiste, ci vuole del tempo o qualcosa del genere?
