View Topics without Login?
The discussion revolves around allowing users to view topics without logging in. SebastianADW wants to share a topic on social media, enabling others to view but not reply. Remah mentions that anonymous web browsing is the default setting, unless a paywall is in operation. However, SebastianADW is experiencing issues with requiring login for topic access and registration for the index page. robmc resolves the issue by directing SebastianADW to the login required setting in Settings, Login. SebastianADW expresses gratitude for the solution, and codinghorror adds that this setting can also be configured in the setup wizard after installation.
Is there a way to invite other people to a special topic?
usecase would be to share a topic on social media, so other people could see what happens in there but cant reply or anything.
I am pretty sure thats possible but i cant find the right Security Setting for it. Would appreciate any help
That’s the default. Anonymous web browsing. Many of us started as lurkers.
Unless you operate a paywall?
When i am trying to invite someone to my topic, he is forced to create an account or to logg in. And when i am trying to connect to my index page its also asking for a registration. Do yu know where i can change that ?
Sounds like you have asked for the site to require login. If you are happy for anonymous users to read content, then click on this setting:
Go to Settings, Login and search for login required
Thank you so much, thats exactly what i was looking for
You can also set this in the setup wizard that runs immediately after install.
