As an admin or moderator, is there a way to view the history of a user’s edits to other people’s posts? And/or a way to view a global history of all edits to others’ posts? I’d like to occasionally do a read-through to make sure such edits are reasonable, and be able to provide feedback to Regular-level members on how to make good edits.
Data Explorer Plugin. The query you will want to start with
SELECT *
FROM post_revisions
You will probably want to eventually add date filters as I believe it limits to 200 results.
We have since added a built in report for this in the admin dashboard.
Awesome, thanks! I’ll check it out.
I think there may be a bug. When I visit https://community.letsencrypt.org/admin/reports/post_edits?end_date=2019-06-05&start_date=2019-05-01, I see “Post Edits — No data to display.”, even if I hit “Refresh Report” multiple times.
I know there are edits because I lifted our restrictions on edits, and we recently got another instance of a spammy edit.
Can you repro this @tshenry
I’m not able to repro at the moment. Still digging.
Hey Jacob, I just wanted to follow up here and let you know the issue with the Post Edits report has been fixed. You should see a nice a full list of post edits on the report going forward
Thanks! This is working great. Interestingly, in the time since I originally reported this, I came across a related need for a Post Edit report. Spammers are posting innocuous things and later editing them to contain links.
The current Post Edit report only shows when User A edits User B’s post, which is definitely what I originally requested. It’s a little confusing though that it leaves out when User A edits User A’s post.
I think my use case is adequately solved by the Data Explorer query described here, so I’m not requesting a code change, but I would recommend tweaking the title of this report to something like “Cross-user edits” or similar.
Thanks again for all your help.
