Hello dears,
Is there any plugin or intention to have something like this in Discourse?
Hello dears,
No plugin or theme that I am aware of. I do not expect us to add something like this to core, but if the community wish to build a plugin or theme, sure!
Very handy utility. Including link to REPL to try it out, and a mindmap that conveys the idea:
mindmap
root((Discourse))
Origins
Long history
Popularisation
British popular psychology author Tony Buzan
Research
On effectiveness<br/>and features
Supports MindMaps already!!!
Uses
Creative techniques
Strategic planning
Argument mapping
Tools
Pen and paper
Mermaid
We support mindmaps now in the mermaid theme component!
example source:
mindmap
root((Discourse))
Origins
Long history
Popularisation
Research
Uses
Creative techniques
Strategic planning
Argument mapping
Tools
Pen and paper
Mermaid
markmap could be implemented, similarly as a theme component I guess.
Oh, lovely
thank you Sam!
(Btw, the mail notification of your post does not contain the mind map, but shows its textual definition instead)
Out of curiosity, I tried to make it work with Markmap because it’s another interesting mindmap. It needs some detailed attention, but it can work. Hopefully, I can share something based on it. ![]()
@Arkshine is there an update on the mindmap
Me too, i am interested.
Dear @Arkshine , could you please tell the “trick” to make it work on Discourse? ![]()
I started to look at it again a few days ago, and I think I’m on the right track to post something soon. ![]()
It’s more work than expected.
On a technical side, Discourse relies on the Markdown-it library to handle markdown and has many custom plugins attached to it.
In my previous video, I used the library from a CDN link. However, markmap, by default, tries to load Markdown-it from a CDN and use another instance. This means you won’t be able to use specific Discourse features in a markmap, so you must implement the library differently to use the instance from Discourse.
Stay tuned. ![]()
