Web server is down Error code 521
The user Ahmed26 is experiencing a 521 Web Server Is Down error after installing a web server on Ubuntu 22.04, with the setup screen failing to load. The issue occurs despite using the same successful installation method as before. Stephen suggests the problem may be related to Cloudflare, as the instance is behind it, and recommends disabling the orange cloud (proxy) and waiting five minutes. Ahmed26 confirms the use of Cloudflare and that disabling the proxy didn’t help. Stephen questions whether the FQDN and Let’s Encrypt were used consistently, and if a rate limit might have been triggered. RGJ notes that the DNS records still show Cloudflare’s IP addresses, indicating the proxy is still active. Ahmed26 expresses concern about recurring 521 and 522 errors and asks for a solution. Ahmed26 later clarifies that the issue resolved after a clean install following multiple failed attempts, suggesting the problem was likely due to previous installation artifacts or rate limits.
I installed it on ubuntu 22.04 setup screen won’t open what could be the problem ?
It looks like this instance is behind CloudFlare, was it installed that way?
Turn off the orange cloud and try again in five minutes.
Was this a fresh server, or was something already installed there?
Did you follow the standard install?
i have installed it 20 times with the same method there was no problem at all. it happened for the first time the installation is correct
yes cloudflare
turning off the orange cloud didn’t work
On the same FQDN? with Let’s Encrypt enabled? Did you hit the rate limit?
But what happened after you did that, because you were definitely not still seeing that Cloudflare error then?
That, and you still have Cloudflare enabled with the orange cloud.
;; ANSWER SECTION:
isciforum.com.  300 IN  A  104.21.23.246
isciforum.com.  300 IN  A  172.67.214.182
i’ve done a lot of installation error 521 522 is it related to this ? how to solve
gave this issue because i did multiple installs It was fixed after 3 days I did a clean install
