¿Webhooks para eliminación/desactivación de usuarios?
Is there an easy way to add webhooks for user deletion and deactivation?
I think I’ve found the relevant code but it appears to only list webhooks for these actions:
user_logged_out
user_created
user_logged_in
user_approved
user_updated
We’re integrating separate applications that get updated with user data each time the Discourse user changes, so I’m looking for a way to remove users’ access from the other systems when the user accounts are deactivated/deleted from Discourse.
Sure not a bad idea to put this on someone’s to-do list .. maybe @vinothkannans? If it is easy we can just knock it out.
Thanks, that would be great, if it’s possible.
PR created:
https://github.com/discourse/discourse/pull/6124
