Site não carrega completamente
This just randomly happened, any ideas? You cant access the site, just shows a blank backgroud :confused:
I’ve tried cleaning the disk drive and rebuilding app too
I’ve tried visiting the site but the connection itself is refused - is there an issue with your
DNS?
I was in the process of rebuilding it through commands so it was down. Can you try again?
OK, seeing same issue as you earlier.
Plugin clash? Have you tried Safe Mode?
It was a plugin, I believe it was the initial-spinner-loading plugin or something. Thank you!
