Hosted site stuck on loading page (colored dots) (01/18/2023 8:05 AM Eastern)
Our site is stuck at the loading page.
https://swi-prolog.discourse.group/
First happened on Chrome on laptop, then same with Microsoft Edge on same laptop. Same with iPhone.
Ping works.
C:\Users\Groot>ping swi-prolog.discourse.group
Pinging swiprolog.hosted-by-discourse.com [2602:fd3f:3:ff01::cb] with 32 bytes of data:
Reply from 2602:fd3f:3:ff01::cb: time=85ms
Reply from 2602:fd3f:3:ff01::cb: time=82ms
Reply from 2602:fd3f:3:ff01::cb: time=80ms
Ping statistics for 2602:fd3f:3:ff01::cb:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 80ms, Maximum = 85ms, Average = 83ms
Also checked sever status at https://status.discourse.org/ and saw all was good.
It is not a fire alarm as we are never so dependent on it that we need it immediately.
Thanks.
It works in safe mode, if that’s any comfort. :slight_smile: Specifically, it works when I select ā€˜disable official plugins’ so that’s going to be something we’re going to need to look at.
Let me see what I can find out. :+1:
Update: It’s looking like an update to the Maths plugin may be the culprit. Someone is looking at it now and we should have a fix in soon. Thanks for the report. :slight_smile:
Hi, sorry for squatting this thread, but we have the exact same issue on our hosted site https://brian.discourse.group/ since an hour or so (worked fine earlier during the day). Using safe-mode with ā€œunoffical pluginsā€ (do we use any?) disabled fixes it as well.
Apologies, didn’t see your update: disabling the math plugin fixes it for us as well :+1:
As the OP I don’t see it that way. :grinning:
If I had this problem and someone else noted the problem before me I would ring in to let others know it is a problem shared by others.
It is nice to know that a company like Discourse is responsive and open to such.
Thanks for ringing in.
I agree. Knowing it’s happening to more than one site can help us narrow down the cause if we’re not able to spot it straight away. It’s genuinely very useful. :+1: :slight_smile:
Sorry it was my mistake. It should be fixed and deployed. Let me know if you see any other issue with this, it’s an old plugin and I cleaned quite a lot.
Thanks for the report!
No worries here, thanks for the reply.
After the problem I disabled both MathJax and AsciiMath on our site.
After seeing your reply reenabled them and then checked if the site was responding with a page refresh, it was, and if the MathJax plugins were working using our custom test page and they were not.
In checking history of change for MathJax
https://swi-prolog.discourse.group/admin/logs/staff_action_logs?filters={"subject"%3A"discourse_math_enabled"%2C"action_name"%3A"change_site_setting"}
noticed your changes with the final one being false for off and last change done by me to enable it.
In checking history for AsciiMath only I made changes today
https://swi-prolog.discourse.group/admin/logs/staff_action_logs?filters={"subject"%3A"discourse_math_enable_asciimath"%2C"action_name"%3A"change_site_setting"}&force_refresh=true
Should they work now?
If not and this takes a day or more to fix I don’t see it being a problem for us, just wondering.
I will investigate but if theres a regression, it shouldnt be hard to fix. Will keep you updated.
@EricGT ok I checked, this is correctly working, you must have updated the topic (great idea btw) when the plugin was disabled, I rebuilt the HTML and it seems all good :ok_hand:
Yes I did edit the title today.
Thanks for the feedback, learned something new, that updating a topic with a plugin disabled could cause such a problem. While I am not a Ruby-on-Rails developer I take it that rebuilt the HTML means a rebake, please correct me if I am wrong.
Thanks for taking the time to look at this, being a developer myself I know such things happen from time to time but taking quick ownership is not so often seen, nice job. :grinning:
Yes it’s a rebake indeed :+1:
