ما وظيفة ✔ هذه في المحرر؟
The one beside delete button. I don’t know what information it gives us.
It appears it’s a “draft saved” indicator, but I’m not for sure.
Makes sense :smiley: :ok_hand:
Exactly what you said, when the :heavy_check_mark: icon appears, it means that the post / topic has successfully been saved in the drafts section, where you can resume it or delete it, whenever you want.
I think we are missing a hover text.
I was just checking that and it definitely doesn’t show up.
Also maybe it is better if that icon is on the right side instead of the left side.
There is no item to hover, it fades away. Nothing to do here, carry on :slight_smile:
Technically we have 5 seconds to do hover buy yeah it is somewhat short.
