admin
regular
Private topic only reachable by people in the granted group during invite.
yes, but only in the same category.
I’m going to try other categories and different forums…
admin
regular
Pretty sure this might be something with private topic, don’t waste more time until I investigate this. Thanks.
If that can help you, the recent change on “subcategory can’t be less restrictive than category” hit my forum at some point. Let me check whether it’s the case here…
No, it’s clean. The category has G1/See, G2/CRS, while the subcat has G2/CRS.
FWIW, the bug remains present on v2.3.0.beta4 +12.
Yes I had a busy week on other subjects, will update when fixed, hopefully next week.
It’s getting late here, I will try it again tomorrow, but I think this should fix it:
Good call @j.jaffeux. I’m sorry my intervention caused you to overwork, but you indeed fixed it.
No worries, it was all my mistake
Thanks for the report and waiting for the fix.
Now, since we’re talking UX, when I tested the fix, I first clicked the “copy link” button, and expected to be able to cancel that action and come back to the previous screen and click “send invite”. I don’t think it’s important once you know it, but sometimes you may change your mind and then you have to redo it all again.
Anyway thanks! Have a nice day.
I didn’t change this behaviour and I think it’s a tradeoff, you either:
In this case I think it’s fine as it is.
@j.jaffeux I just realized that I can no longer invite a user (by email or internally) to a topic on mobile since clicking “share” brings up the Android OS “share popup”
I believe that was already discussed at some length? I recall it being discussed in the past.
Even when you click the post date?
There’s some discussion on it but it’s unclear as to what the final state was - I inferred we wouldn’t want leave a feature like that as “desktop only”.
I can get the link just fine, or even “Copy to Clipboard” from the share dialog, but I can’t get to the “invite user” modal.
Yes in this case it might not show, I can probably do something about it.
FWIW, I often want to invite clients to a discussion that they should see and miss being able I do that in Mobile. Just tune I tried on desktop is /I was unable to find the invite link.
Is that an android-only limitation? On iOS once I dismiss the share sheet I see the normal Discourse share/invite dialog.
On Android dismissing the OS dialog does not make the Discourse share modal appear.
I too have noticed this. Looks like we are on Discourse 2.3.0.beta5
iOS :
On iOS the share/invite function is not intuitive at all since the update.
Android:
That should improve it:
