Wat is 'Gebruikers uitnodigen voor een PM'?
Can you help me explain this?
I set the “min trust level to invite” to TL2, but TL1 users can still invite users to PM.
It sounds a little like you mean ‘they can create PMs’? If so, that’s a separate setting.
I’ll have a run through of the invite feature when I get a moment to see if it’s working as expected, just to make sure. :+1::slightly_smiling_face:
Really appreciate your reply! :slightly_smiling_face:
No, they do can invite users into a existing PM.
Is this a version issue? The discourse version of my forum is 2.8.8, not the latest.
I’ve just had a run-through and it seems to be working okay for me. :+1:
I created a PM between a TL2 and a TL1 test user, and tried to invite another non-member to the PM using the :link: menu at bottom of the PM:
However, for my TL1 user there is no Invite option:
Does that help?
Thank you very much!
I totally get it now. I’m not a native English speaker, I mistook “invite user” for “add user” earlier.
Sorry for the stupid mistake I made. :upside_down_face:
There is no need to apologise, it is one of the lesser-known Trust Level perks so can often catch people out. :slight_smile:
