מהי הדרך הטובה ביותר להוסיף בוט צ'אט חיצוני לקהילתנו?
סיכום מבוסס בינה מלאכותית
A user (efuetatem1) sought help in integrating a Microsoft bot service into their Discourse instance. They shared a script provided by their developer, which didn’t work when added to the header customization.
Arkshine suggested that the issue might be due to the script being inserted after the page is loaded, and recommended putting the scripts/styles in the <head> of a theme component attached to the theme. They also mentioned the possibility of needing to adjust the Content Security Policy (CSP) settings to allow the links, as hinted by anon48433008.
The user (efuetatem1) confirmed that the solution worked, and expressed gratitude for the help provided.
Greetings,
So we just made a bot for our two websites using the Microsoft bot service. I wondered about the best way to add the bot to our Discourse instance. Any ideas will be of great help.
Here is a script the developer sent, but when I add it under the header in customization, it doesn’t work. Either there’s a problem with the script or I’m not doing it correctly.
I added the Brevo Customer Service bot to our Discourse instance simply by adding the tracking code on Google Tag Manager, which is then attached to our Discourse instance.
And I have a second question. Google Tag Manager says some of our pages are not being tagged. How is that possible?
Thanks for your time and help,
The bot script that was sent to me by the developer:
   <link rel="stylesheet" href="https://chatbotcdn-e2cybmebhsava5h5.z01.azurefd.net/botfile/chatbot.css" />
To see how the bot looks: world-like-home.com
Our discourse instance where I want to add the bot too : world-like-home.community
Screen of Google Tag Manager
Maybe add to content security also?
I can see your script on your forum. However, it’s likely being inserted after the page is loaded, and that’s why the chatbot doesn’t load.
This should work if you put the scripts/styles in <head>[1] of a theme component attached to your theme.
As Robert stated, you might need to adjust the CSP setting to allow the links.
  1. ↩︎
Thanks very much, @anon48433008 and @Arkshine
It worked.
I appreciate your time and efforts.
Nice day from the JO in the city of love :blush:
