מהי הדרך הטובה ביותר לבנות צינור לפרסום נתוני סריקה לקטגוריות Discourse עם תבניות מבוססות טאב appropriately מותאמות אישית?
סיכום מבוסס בינה מלאכותית
The discussion is about building an automated pipeline to post scraped data into Discourse categories with custom tab-based themes. Steve_John outlined the desired pipeline:
  1. Scraping content from sources
  2. Structuring data with metadata
  3. Using the Discourse API to create topics and update content within specific tabs.
For storing and rendering scraped data, Steve_John is considering two options:
  1. Local database or external CMS
  2. YAML/JSON files.
Pfaffman suggested looking into the RSS polling plugin, but Steve_John mentioned that the scraped data is stored in a standalone database. Pfaffman recommended writing the scraper in Ruby and integrating it into a plugin or using the Discourse API Ruby gem.
Steve_John has already developed the scraper in Python and is now evaluating how to render the data stored in MongoDB.
We want to build an automated pipeline that that can update the discourse custom theme what we built which has different tabs for different kind of scrapped data content:
  1. Scrapes content from sources (RSS feeds, websites, etc.)
  2. Structures the data with metadata: title, source, type (news/conferences) , URL, date
  3. Uses the Discourse API to:
  • Create a topic under the correct category and update content within specific tabs of custom theme.
  • Add relevant tags (to make it appear under the correct tab)
what are best way to store scrap data and render:
  1. local database or external CMS to store and schedule content or
  2. YAML/JSON Files (Static Source)
Maybe have a look at RSS Polling
Thanks pfaffman for the plugin suggestions. However, we don’t have rss feed data, we are storing scrapped data into standalone database..can we use this plugin to connect to the standalone database and fetch the needed data and render the content
It was an example. You could either make your scaped data into an rss feed or modify the plugin to read whatever format you want to put it in.
What I would probably do is write the scraper in ruby and integrate it into a plugin.
Or maybe Use the Discourse API ruby gem and put it in a Github action and have it push the data. I’m planning to do that for a client that’s hosted and can’t use a custom plugin.
Thanks Jay. Already scrapper development is completed with python …now we were evaluating how to render this scrapped data which is stored in monodb.
