When groups filter has no matches, filter field disappears
The issue discusses a bug in the group filtering feature where, when no users match a filter, the filter field disappears, misleading users into thinking the group is empty. Stephen reports that the filter field vanishes after entering a non-matching search term, making it impossible to correct the filter without navigating back or editing the URL. awesomerobot acknowledges the oversight, explaining that the filter was hidden under the assumption that no members meant no need for the filter. They quickly fixed the issue by reverting the behavior to show the filter field even when no matches are found. Stephen humorously notes the rapid response time, and awesomerobot credits the quick fix to being in the right place at the right time.
When filtering the members of a group by username or email using the field above the users list, the following happens:
enter text which matches no users:
The filter field disappears, and the message improperly suggests the group is empty, rather than there being no users matching the filter.
The filter can’t be corrected either, because the field is gone. The user is forced to browse back to the group view without a filter, or to edit the filter which appears in the URL.
** v2.0.0.beta10 +20**
Ah good point… that’s annoying, I hid the filter thinking that it’s not necessary if a group has zero members… but I didn’t account for the fact that filtering in itself creates a “no member” state.
Just made an update that fixes that. Ideally we should know the difference, but just reverting back to what it was originally for now.
https://github.com/discourse/discourse/commit/8b96d9a52d771397d328c3126ba7f717c0528290
Eight minutes, is that a new record for a response and fix?
Just one of those things where the stars aligned and I happened to be looking at the right place at the right time and knew exactly what caused the problem (me). :wink:
This topic was automatically closed after 26 hours. New replies are no longer allowed.
