Dove posso vedere i post creati da me?
I want to see topics as well as all replies created by me
Also, my posts somewhere on main page itself
Thanks
topics
https://meta.discourse.org/u/<username>/activity/topics
replies
https://meta.discourse.org/u/<username>/activity/replies
So, everytime a user has to go hamburger menu to go to “Activity” section?
Also, what would be the relative url for activity section?
Can you help with this? I can add link using custom menu component for activity page
Thanks for help
The part of the url after the main url should work I guess.
I tried. It’s not working. Using this m creating link- My activity in menu itself.
The URL is not working
You’ll need to read the component’s page and ask the question there.
I got the answer from this user
https://meta.discourse.org/t/custom-top-navigation-links/87225/25?u=ankitjain
Thanks for all the help
However there is no need of a theme component, Discourse itself can create a “My Posts” button adding to the site setting top menu the posted entry:
Ohh, you are right.
But is it a good practice to use MY ACTIVITY link instead of posted?
Your advice please
It’s a good practice when you need to add a link to a custom code or to a topic (for example in a guide: “Go to your activity page to see X and Y…”), but if the button is already provided by default (it’s only disabled) why install a theme component that you don’t need?
You are awesome. Thanks
