Dove posso disabilitare esattamente Discobot?
Hi,
please tell me where I can find the option of disable discobot.
If you go to Admin and then to your Settings, you will find the details under plugins
Alternatively, filter for discourse narrative bot settings
5 Mi Piace
Since the Discourse Narrative Bot is referred to almost exclusively as “discobot”, it might be helpful to include a parenthetical “(Discobot)” in the setting description, then a search for “discobot” would find the setting.
8 Mi Piace
Sure this has come up a few times @jomaxro can you take that change? It’s only a copy change.
2 Mi Piace
Easy enough, that’s done.
8 Mi Piace
