How do I disable Discobot?
I really need to destroy Discobot. I haven’t been able to find a kill switch, and I can’t block the user. Can someone please advise?
Edit: Is it narrative bot? If so I’ve found it under plugins :slight_smile:
yes - it’s the narrative bot plugin.
Thanks! DIE DISCOBOT!!
Hey,
There is actually a checkbox in your settings that will disable it.
