I’ve looked all through all the settings and done a search but I can’t find where to change the default icon that shows in the browser tab
Does anyone know where to fix this without getting into custom custom code?
It’s usually called a favicon.
Maybe you will find some hints in these topics.
Apparently, you have to (re-)run the setup wizard:
If you go to site settings and search favicon
you can change it from there. This is contained within the ‘Branding’ section of the settings. This is quicker than running the wizard again.
Thanks. This did the trick. The first time I tried it didn’t work so I tried it again and cleared the cache.
