How does this line work? I can not find where the method defined or how the function defined.
I mean if i want to add a top-menu, how does it works?
I believe top menu is a string in the format: “first|second|third|fourth”
IE, a pipe delimited array in a string.
To add a top-menu item use this:
https://meta.discourse.org/t/adding-items-to-navigation-bar/26830/8?u=falco
