איפה למצוא שורת חיפוש בהגדרות שלנו?
סיכום מבוסס בינה מלאכותית
Summary
The discussion revolves around finding the search bar in settings for a paid Discourse community. Maartje initially asked where to find the search bar, and pfaffman suggested the Easy Google Search Bar. However, Moin clarified that Maartje might be looking for a theme component like the search banner or header search.
After Maartje provided a screenshot of the desired search bar, Moin guided them through the process of installing the search banner theme component. This involved going to the Appearance section in the admin sidebar, installing the component from a git repository, and configuring the settings. Finally, Maartje confirmed that they found the solution, thanking Moin for the help.
We are not hosting our community but have a paid version.
Where do I find the search bar in our settings??
Thanks!
maybe you want Easy Google Search Bar?
Which search bar are you talking about?
Do you want to install a Customization > Theme component like Advanced Search Banner or Advanced Header Search?
Sorry, to be more specific I would like to have a search bar like this discourse:
Then you want to install the Advanced Search Banner Customization > Theme component
The settings for themes and theme components are located in the Appearance section of the admin sidebar:
There you can click Install, select “From a git repository” and add the repository link you find in the table in the topic about the component.
After installing, you can change the settings and translations.
I usually open the preview, because I can see the effect of my setting changes.
When you are satisfied with the settings, don’t forget to add the component to your theme.
Amazing we found it!!! thanks
