Milenski
(JustMe)
8 Gennaio 2026, 3:26am
1
Discourse sta avendo problemi? Quando provo a caricare la pagina di amministrazione per un aggiornamento, ottengo questo errore: “while trying to load /admin/docker/repos Error code: 500 error”.
Ricordo che questo accadeva quando veniva implementato un nuovo plugin e veniva anche installato sul sistema. Ma ora non ne ho installati, e uso solo quelli implementati.
Ho eseguito:
cd /var/discourse
./launcher rebuild app
E tutto è andato liscio, ma lo stesso errore si verifica di nuovo per la pagina di aggiornamento nel pannello di amministrazione.
Allego anche un backtrace da /logs qui:
NameError (uninitialized constant Discourse::VERSION::PRE) app/controllers/application_controller.rb:440:in `block in with_resolved_locale' app/controllers/application_controller.rb:440:in `with_resol
plugins/docker_manager/app/controllers/docker_manager/admin_controller.rb:185:in `discourse_upgrade_required?'
plugins/docker_manager/app/controllers/docker_manager/admin_controller.rb:67:in `repos'
actionpack (8.0.4) lib/action_controller/metal/basic_implicit_render.rb:8:in `send_action'
actionpack (8.0.4) lib/abstract_controller/base.rb:215:in `process_action'
actionpack (8.0.4) lib/action_controller/metal/rendering.rb:193:in `process_action'
actionpack (8.0.4) lib/abstract_controller/callbacks.rb:261:in `block in process_action'
activesupport (8.0.4) lib/active_support/callbacks.rb:120:in `block in run_callbacks'
i18n (1.14.7) lib/i18n.rb:353:in `with_locale'
app/controllers/application_controller.rb:440:in `with_resolved_locale'
activesupport (8.0.4) lib/active_support/callbacks.rb:129:in `block in run_callbacks'
app/controllers/application_controller.rb:1073:in `ensure_dont_cache_page'
activesupport (8.0.4) lib/active_support/callbacks.rb:140:in `run_callbacks'
actionpack (8.0.4) lib/abstract_controller/callbacks.rb:260:in `process_action'
actionpack (8.0.4) lib/action_controller/metal/rescue.rb:27:in `process_action'
actionpack (8.0.4) lib/action_controller/metal/instrumentation.rb:76:in `block in process_action'
activesupport (8.0.4) lib/active_support/notifications.rb:210:in `block in instrument'
activesupport (8.0.4) lib/active_support/notifications/instrumenter.rb:58:in `instrument'
activesupport (8.0.4) lib/active_support/notifications.rb:210:in `instrument'
actionpack (8.0.4) lib/action_controller/metal/instrumentation.rb:75:in `process_action'
actionpack (8.0.4) lib/action_controller/metal/params_wrapper.rb:259:in `process_action'
activerecord (8.0.4) lib/active_record/railties/controller_runtime.rb:39:in `process_action'
actionpack (8.0.4) lib/abstract_controller/base.rb:152:in `process'
actionview (8.0.4) lib/action_view/rendering.rb:40:in `process'
rack-mini-profiler (4.0.1) lib/mini_profiler/profiling_methods.rb:116:in `block in profile_method'[ ](https://github.com/rack/rack/blob/master/mini_profiler/profiling_methods.rb#L116)
actionpack (8.0.4) lib/action_controller/metal.rb:252:in `dispatch'
actionpack (8.0.4) lib/action_controller/metal.rb:335:in `dispatch'
actionpack (8.0.4) lib/action_dispatch/routing/route_set.rb:67:in `dispatch'
actionpack (8.0.4) lib/action_dispatch/routing/route_set.rb:50:in `serve'
actionpack (8.0.4) lib/action_dispatch/routing/mapper.rb:32:in `block in <class:Constraints>'
actionpack (8.0.4) lib/action_dispatch/routing/mapper.rb:62:in `serve'
actionpack (8.0.4) lib/action_dispatch/journey/router.rb:53:in `block in serve'
actionpack (8.0.4) lib/action_dispatch/journey/router.rb:133:in `block in find_routes'
actionpack (8.0.4) lib/action_dispatch/journey/router.rb:126:in `each'
actionpack (8.0.4) lib/action_dispatch/journey/router.rb:126:in `find_routes'
actionpack (8.0.4) lib/action_dispatch/journey/router.rb:34:in `serve'
actionpack (8.0.4) lib/action_dispatch/routing/route_set.rb:908:in `call'
railties (8.0.4) lib/rails/engine.rb:535:in `call'
railties (8.0.4) lib/rails/railtie.rb:226:in `public_send'
railties (8.0.4) lib/rails/railtie.rb:226:in `method_missing'
actionpack (8.0.4) lib/action_dispatch/routing/mapper.rb:33:in `block in <class:Constraints>'
lib/middleware/omniauth_bypass_middleware.rb:35:in `call'
lib/middleware/crawler_hooks.rb:11:in `call'
rack (2.2.21) lib/rack/tempfile_reaper.rb:15:in `call'
rack (2.2.21) lib/rack/conditional_get.rb:27:in `call'
rack (2.2.21) lib/rack/head.rb:12:in `call'
actionpack (8.0.4) lib/action_dispatch/http/permissions_policy.rb:38:in `call'
lib/middleware/anonymous_cache.rb:416:in `call'
lib/middleware/csp_script_nonce_injector.rb:12:in `call'
config/initializers/008-rack-cors.rb:14:in `call'
rack (2.2.21) lib/rack/session/abstract/id.rb:266:in `context'
rack (2.2.21) lib/rack/session/abstract/id.rb:260:in `call'
actionpack (8.0.4) lib/action_dispatch/middleware/cookies.rb:706:in `call'
actionpack (8.0.4) lib/action_dispatch/middleware/callbacks.rb:31:in `block in call'
activesupport (8.0.4) lib/active_support/callbacks.rb:100:in `run_callbacks'
actionpack (8.0.4) lib/action_dispatch/middleware/callbacks.rb:30:in `call'
actionpack (8.0.4) lib/action_dispatch/middleware/debug_exceptions.rb:31:in `call'
actionpack (8.0.4) lib/action_dispatch/middleware/show_exceptions.rb:32:in `call'
logster (2.20.1) lib/logster/middleware/reporter.rb:40:in `call'
lib/middleware/default_headers.rb:13:in `call'
railties (8.0.4) lib/rails/rack/logger.rb:41:in `call_app'
railties (8.0.4) lib/rails/rack/logger.rb:29:in `call'
config/initializers/100-quiet_logger.rb:20:in `call'
config/initializers/100-silence_logger.rb:29:in `call'
actionpack (8.0.4) lib/action_dispatch/middleware/request_id.rb:34:in `call'
lib/middleware/enforce_hostname.rb:23:in `call'
rack (2.2.21) lib/rack/method_override.rb:24:in `call'
actionpack (8.0.4) lib/action_dispatch/middleware/executor.rb:16:in `call'
rack (2.2.21) lib/rack/sendfile.rb:127:in `call'
rack-mini-profiler (4.0.1) lib/mini_profiler.rb:334:in `call'
message_bus (4.4.1) lib/message_bus/rack/middleware.rb:60:in `call'
lib/middleware/request_tracker.rb:321:in `call'
actionpack (8.0.4) lib/action_dispatch/middleware/remote_ip.rb:96:in `call'
lib/middleware/overload_protections.rb:22:in `call'
lib/middleware/processing_request.rb:14:in `call'
rack (2.2.21) lib/rack/urlmap.rb:74:in `block in call'
rack (2.2.21) lib/rack/urlmap.rb:58:in `each'
rack (2.2.21) lib/rack/urlmap.rb:58:in `call'
unicorn (6.1.0) lib/unicorn/http_server.rb:634:in `process_client'
unicorn (6.1.0) lib/unicorn/http_server.rb:739:in `worker_loop'
unicorn (6.1.0) lib/unicorn/http_server.rb:547:in `spawn_missing_workers'
unicorn (6.1.0) lib/unicorn/http_server.rb:143:in `start'
unicorn (6.1.0) bin/unicorn:128:in `<top (required)>'
vendor/bundle/ruby/3.3.0/bin/unicorn:25:in `load'
vendor/bundle/ruby/3.3.0/bin/unicorn:25:in `<main>'
Sarei felice se qualcuno sapesse qualcosa sull’argomento e potesse aiutare.
2 Mi Piace
david
(David Taylor)
8 Gennaio 2026, 10:13am
Grazie per le segnalazioni. Ho una correzione in fase di sviluppo:
main ← version-pre
merged 10:14AM - 08 Jan 26 UTC
This will always be `nil` under the new versioning scheme, so it was removed in … 723e872556efb90b9248ae0d69775acdaff3efe8. However, some plugins (including docker_manager) are checking the value of `::PRE`, so this was inadvertently a breaking change.
Pubblicherò di nuovo qui una volta che sarà disponibile su latest
3 Mi Piace
Stesso errore qui dopo aver installato gli aggiornamenti oggi, la ricostruzione non ha aiutato.
Gli aggiornamenti sono stati installati correttamente ieri e non ho mai visto questo errore prima.
[default] NameError (uninitialized constant Discourse::VERSION::PRE) app/controllers/application_controller.rb:440:in `block in with_resolved_locale' app/controllers/application_controller.rb:440:in `
lib/middleware/content_security_policy.rb:12:in `call'
rails_multisite (7.0.0) lib/rails_multisite/middleware.rb:26:in `call'
unicorn (6.1.0) bin/unicorn:128:in `<required>`
4 Mi Piace
Anch’io ho riscontrato questo problema, la ricostruzione (rebuild) due volte non ha risolto il problema, in attesa di una correzione.
david
(David Taylor)
8 Gennaio 2026, 2:59pm
6
Siamo spiacenti per il ritardo: oggi abbiamo avuto alcuni problemi non correlati con la nostra CI.
La correzione è ora attiva su latest, quindi un nuovo aggiornamento dovrebbe risolvere il problema. Fateci sapere in caso contrario.
1 Mi Piace
david
(David Taylor)
Ha separato questo argomento il
9 Gennaio 2026, 10:54am
7
Milenski
(JustMe)
9 Gennaio 2026, 5:05am
14
Confermo, il problema è risolto. Dopo una ricompilazione tramite il terminale è tutto a posto. Grazie.
david
(David Taylor)
9 Gennaio 2026, 10:56am
15
Ho separato la discussione sulla migrazione fallita in un argomento separato:
重新rebuild 失败了~日志如下:
discourse -c 'bundle exec rake db:migrate'
rake aborted!
StandardError: An error has occurred, this and all later migrations canceled: (StandardError)
You must drop a column's default value before marking it as readonly
I, [2026-01-08T16:18:49.016491 #1] INFO -- : Terminating async processes
I, [2026-01-08T16:18:49.018961 #1] INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/pos…
Chiuderò questo argomento, dato che abbiamo la conferma che l’errore ::PRE è stato risolto. Grazie ancora per le segnalazioni!
1 Mi Piace
