Why can't users invite others to messages when account approval is enabled?
XieLong reported an issue where Trust Level 2 (TL2) and TL3 users cannot invite existing users to group messages on a Discourse v1.7.2 instance, despite admins having this capability. The forum uses account approval settings and users were imported via a script. codinghorror initially suggested SSO or disabled local auth might be the cause, but elijah clarified that inviting existing users to topics should still work with SSO. codinghorror agreed that TL2 users should be able to add existing accounts to group messages. XieLong investigated further and identified the root cause in lib/guardian.rb within the can_invite_to? method, which incorrectly blocks invites if must_approve_users? is enabled unless the user is staff. codinghorror acknowledged this as a bug since inviting existing users to PMs should not be restricted by the approval setting. techAPJ confirmed the issue was fixed via a commit to the repository.
Hi!
In my Discourse instance I have the problem that users would like to invite (and remove) other users to (group) messages - but they can’t although all of them have trust level 2 (it’s just a small user base).
What trust level or permissions or settings are required for a user to invite someone to an existing message thread?
If you have SSO enabled, invites are no longer possible as they would bypass SSO authentication.
Also if you have disabled local auth (username/password accounts) invites are also no longer possible.
Invite to a topic is different than invite to a forum. You should still be able to invite existing users to participate in a topic with SSO. I believe that is the request here.
3 Me gusta
I see, thanks for the clarification @elijah, if we are talking about adding existing accounts to a group message, I can’t think of any reason TL2 users wouldn’t be able to do that.
1 me gusta
That’s exactly what my question is about.
All accounts were created by importing them via an Import-Script (based on the punBB Importer) and than assigned trust level 2 (as they were already established members of the old forum).
All admin accounts are able to invite users to group messages. T2 and T3 users not.
More infos: Discourse is v1.7.2 (stable)
Sounds like something possibly went awry in the import, is my only guess.
I found the problem(?) with my setup.
In lib/guardian.rb method can_invite_to? there is the following check:
return false unless (!SiteSetting.must_approve_users? || is_staff?)
and my forum is set up to require staff approval of new members, so that’s why there’s no invitation to group messages. It’s kinda unexpected to have that check for users to invite others to group messages.
PS: A hard coded trust level requirement (last line of the mentioned method) also seems kind of odd. But I’m not sure as I’m really new to discourse (and Ruby in general)
5 Me gusta
Hmm technically this is a bit of a bug @techapj as inviting existing users to a PM should not be disallowed in this condition.. thanks for tracking that down @XieLong.
6 Me gusta
Fixed via
https://github.com/discourse/discourse/commit/dc2171960bef96eab1269405233dd41603d28417
5 Me gusta
