Por que as métricas de nível de tópico não aparecem para certos tópicos?
Normally, we see reply, view, user, likes, and link count at the bottom of the original post, but occasionally this info won’t appear. While I assume that could mean no one has visited the topic, in this particular case, there are no replies, but I can see several links within the post have been clicked more than once, which leads me to believe that some users have viewed the topic.
Any ideas?
Could you illustrate this with a screenshot or two?
Certainly!
Normally, I see something like this at the bottom of every original post in a topic:
For the topic in question (and I’ve seen this on a few others), the info at the bottom of the original post doesn’t appear:
Ah, AFAIK that only slides into view below the original post once there has been participation in a topic.
Your screenshot where it’s missing has one hidden reply. Is it a flagged post?
1 reply:
0 replies:
Thanks!
No, the hidden post (on both screenshots) is just where I made the topic listed.
Does that mean users viewing the topic and clicking links doesn’t count as participation in the topic?
The element you’re talking about is the topic map.
It’s not really a topic if nobody responds, is it? The name seems pretty appropriate, a map with only one point isn’t much use :slight_smile:
Got it. Thanks for your help!
I understand your logic regarding what constitutes a topic, however, there’s still value in users visiting/reading content in a forum even if they don’t respond. For that reason, it’s helpful for us to see these metrics for every topic.
Is replying to the topic the only way to trigger the topic map? Are there any hacky ways I can make that happen for topics with no replies?
No, there must be at least one reply to see the topic map.
Prezado @codinghorror, @Stephen e toda a equipe do Discourse,
Percebi que Show topic-map without a reply trata da mesma solicitação de recurso descrita neste tópico. O que estamos pedindo seria o inverso de Removing topic summary underneath first post. Embora um pouco diferente, notei que vocês já ajustaram esse recurso recentemente por meio de Topic-map-summary only shows the likes of the first post.
Deixe-me contar nossa história.
Temos um tópico razoavelmente popular em Developing Grafana Worldmap NG - Benutzerschnittstelle / User interface / API - Hiveeyes, que tem sido nosso “tópico de bancada” por algum tempo, e um tópico irmão criado recentemente em Panodata Map Panel for Grafana - The workbench - Panodata Community, que atua como um resumo/conclusão do primeiro.
Embora entendamos os comentários acima, achamos que seria muito legal poder ver o widget Mapa de Tópicos/Resumo também em tópicos que não têm nenhuma resposta nem qualquer outra interação, como acontece com o último tópico mencionado acima.
Entendo que as métricas de “respostas”, “usuários” e “curtidas” possam simplesmente aparecer como zero, mas tornar a métrica de “visualizações” visível para cada visitante, bem como a seção “Links Populares”, seria valioso para nós.
Portanto, peço humildemente que considerem exibir o Mapa de Tópicos como uma opção, talvez ativada por uma configuração específica, mesmo quando não houver nenhuma resposta ao tópico.
Obrigado por ouvir, mantenham o espírito e, com os melhores cumprimentos,
Andreas.
