Mensaje de error de WP Discourse: más de 32000 caracteres
Hey there
@simon Maybe you know this one
I tried to update this post to the linked discourse topic, but I get the error message that it exceeded 32000 character, which is not the case. publishing the post to discourse worked without any issues
FIY I use the following functions.php entries:
// show wp posts embedded in discourse via iframe
// https://meta.discourse.org/t/wp-discourse-how-to-deal-with-shortcodes-in-post/58838/5
add_filter( 'discourse_publish_format_html', 'wpdc_custom_discourse_publish_format_html', 10, 2 );
function wpdc_custom_discourse_publish_format_html( $output, $post_id ) {
    $permalink = get_the_permalink( $post_id );
	$content_post = get_post( $post_id );
	$content = $content_post->post_content;
	$content = apply_filters('the_content', $content);
	$content = str_replace(']]>', ']]>', $content);
	ob_start();
    <iframe width="690" height="2000" src="<?php echo esc_url( $permalink ); ?>" frameborder="0"></iframe>
	<div data-hide="true"><?php echo $content; ?></div>
	<?php
    $output = ob_get_clean();
    return $output;
// upwork by njegos vukadin
add_action( "wp_head", "detect_embedding", 1 );
add_action( "wp_head", "modify_embedded_links", 11 );
function detect_embedding()
<script>
    function isEmbedded () {
	    try {
	        return window.self !== window.top;
	    } catch (e) {
	        return true;
	if( isEmbedded() ){
		document.documentElement.className = document.documentElement.className + " embedded";
</script>
<style>
	.embedded body > *:not(#page),
	.embedded #main > *:not(article),
	.embedded #right-sidebar {
		display:none!important;
		visibility:hidden!important;
	.embedded #main {
		margin:0;
</style>
<?php
function modify_embedded_links(){
<script>
    jQuery(document).ready(function($){
		if( isEmbedded() ){
			$("a").filter(function(){
				return this.href.split("#")[0] !== window.location.href.split("#")[0];
			}).attr("target","_blank");
</script>
<?php
The error message is the response that is returned from Discourse when you publish the post. I am surprised that the post was published with the error.
Since you are publishing the entire post as an iframe, I’m not sure why you are adding the post content after the iframe.
1 me gusta
to make sure the post gets some relevance for the discourse search
