צריך להתחבר או להירשם לפני המשך
סיכום מבוסס בינה מלאכותית
A discussion about triggering a “You need to sign in or sign up before continuing” message in Discourse. Jonathan5 inquired about the settings for this effect, initially thinking it was a plugin or theme component. HAWK clarified it was a different screen, and Don suggested it might be related to DiscourseConnect. However, Jonathan5 experienced the message popping up while reading a topic, and Don suspected it might be due to accidental tapping of the like button on mobile devices. Jonathan5 confirmed this was the case, and now prefers the default Discourse behavior, which greys out the topic and displays a login modal.
Continuing the discussion from Discourse Reactions - Beyond Likes:
What are the settings to achieve this effect? I’m currently using the guest gate theme component but would prefer to use standard settings if possible. Thanks.
Ah, I see. That is not the screen that I was referring to. I was talking about this one:
I thought you might have been, though wasn’t sure. Maybe @seanblue knows :slight_smile:
I think that is with DiscourseConnect. Redirect to the main site to login or register.
I can imagine the login/registration process using that. But how does the “you need to sign in” message know to pop up when it does? I was reading the topic and after a while it just appeared.
I checked the site again and nothing Popup for me. I think if you use mobile, probable you accidentally tap the like button while scrolling and it redirected to the main site. Many times happens to me :slightly_smiling_face:
I think you are right! It happens when I scroll down the page using my right thumb, which is in line with the like button. It’s odd, as it happens during the scrolling process (as well as when I deliberately click the heart). The software must react more quickly than me to what my own thumb is doing.
I now prefer the default Discourse behaviour, which greys out the topic and overlays a “Welcome back!” login modal. Less confusing to tired people like me today :slight_smile: And the Guest Gate theme component is good at what it does too.
