Youtube scrolling bug
A bug on YouTube has been reported where embedded videos reload when scrolling up or down while the post containing the video is still visible. ky_metro reproduced the issue in Firefox and Chrome stable, providing repro steps and example links. purldator confirmed the issue and suggested it might be related to YouTube links that start the video from a specific spot.
However, further testing revealed that the bug is more tied to the post containing the video, not the video itself. ky_metro found that keeping a tiny bit of the video’s post on screen while scrolling around causes the video to reload every time the URL updates. Once the post goes off screen, the video stops.
@codinghorror and @ky_metro were able to reproduce the issue. A fix has been implemented by eviltrout to prevent the video from restarting when scrolling to different posts. However, the issue of the video stopping when off screen is due to the site’s cloaking feature, which unloads content to save memory. eviltrout suggests increasing the threshold or adding a check to see if a video is playing, but considers it a less serious bug.
Youtube bug in the new virtual DOM. Tested in Firefox and Chrome stable.
Repro:
  • Play a Youtube video embedded in a post, and scroll up or down but the post itself is still visible.
  • The URL bar will refresh as another post (before or after) becomes visible.
  • The video should continue playing. Instead, it reloads, beginning playback again from the beginning.
  • Every time the URL updates and the containing post is partly visible (even if the video itself is offscreen) it will reload.
  • If you scroll up or down until the containing post is offscreen, the video stops and doesn’t reload until you click it again.
See example here:
Another one here:
https://meta.discourse.org/t/the-end-of-clown-vomit-or-simplified-category-styles/24249/144
2 „Gefällt mir“
This may be related to YouTube links that start the video from a specific spot.
For instance, the example you linked involved the video starting @ 2:26.
This is the precise URL I used for that post: https://youtu.be/ZKpFFD7aX3c?t=2m26s
Otherwise, confirmed from my side based on your repro steps.
Well, lets try it with a different one.
https://meta.discourse.org/t/the-end-of-clown-vomit-or-simplified-category-styles/24249/144?u=ky_metro
The repro steps in your OP did not conjure the same bug as seen from my post. RE: simplified category styles post.
I start that video, scroll down, the video stops. I scroll back up, press play anew, let it run a bit then scroll up; it stops. Intended behavior. I am on latest Chrome/Windows 10.
So, this narrows down to videos that start from a spot specified in the URL.
That’s interesting. For me it did the same thing as repro steps, restarted playing. I’m on latest Chrome / Win10 too.
Try disabling all your plugins/extensions? Then test anew.
After some experimenting, I’ve updated the repro steps. Its more tied to the post which contains the video, not the video itself.
Keep a tiny bit of that video’s post onscreen as you scroll around, and the video will reload every time the URL updates. Once the post goes offscreen, the video stops.
2 „Gefällt mir“
Yep I can repro this @eviltrout
I’ve got a fix here for the video restarting when scrolling to different posts:
https://github.com/discourse/discourse/commit/65d7103bdc20d597decaeefa6ae9c782d6d51aaa
As for it stopping when offscreen: that’s the result of our cloaking, which tries to save memory by unloading things as they scroll off. We might be able to increase the threshold before this happens, or perhaps add a check to see if there’s a video playing, but I think it’s less serious of a bug.
4 „Gefällt mir“
I’m all for turning a bug into a new feature. Facebook does this too, right?
Unless you’re listening to music, I can’t see needing to keep the video running offscreen.
