Zapier: https://zapier.com/
Integromat: https://www.integromat.com/en/
See also here:
https://meta.discourse.org/t/put-in-a-vote-for-discourse-in-zapier-apps/21858
The discussion evaluates integrating Discourse with Zapier or similar services like Integromat. tophee initially suggests both platforms and notes a separate thread for voting on official integration support vote for discourse in zapier apps. mikechristopher supports better integration, while tophee explains that official Zapier integrations are often maintained by the service provider, not the third-party app, and suggests Integromat may offer more customization for developers. codinghorror questions the relevance since Discourse already supports webhooks. Wil points to an existing Zapier app listing, though tophee notes it only supports one-way triggers. Wil clarifies that while Discourse can send data to Zapier via webhooks, triggering actions in Discourse from Zapier is not natively supported. Consequently, erlend_sh closes the feature request as there is no action for the Discourse team to take, directing further discussion to the existing voting thread.
See also here:
Most definitely up for having Zapier and Discourse work in hand together better than they do already via webhooks! However I think we also need Zapier to work on it too.
I think that’s what the other thread I referenced is about. However, my impression is that the best way to get a zapier integration (and one that works) is by doing it yourself. Most companies seem to provide their own zapier integration. At least zapier support often tell me that they can’t fix it because the integration is maintained by whatever company it is.
Having said that, I am not sure zapier is the best service to focus on. Their integrations are pretty basic and geared towards the consumer market. Their benefit, of course, is in being the market leader. Integromat let’s you basically design your own custom integration with a lot of detail, including text processing and what not.
The question is who would this integration be aimed at. If it is admins and developers, I think something like integromat would be better. If the idea is that any forum member should be able to, I don’t know, pull all posts in a specific category over to their dropbox, then zapier might be better.
The only open source alternative seems to be bip.io but they don’t even keep their SSL certificate up to date…
Er.. what? We have webhooks so this has zero to do with us, and this “integration” makes no sense?
If we are missing a webhook that could be a legit “integration” issue?
I think that doesn’t mean anything. They have that kind of “announcement” for pretty much every service…
What’s perhaps more interesting is how you can use zapier already now:
Through webhooks you can do Discourse → Zapier but not Zapier → Discourse though
Since there’s nothing we can do on our end with this integration, I’m closing this request (also so that we can test if closing will return votes correctly @sam … edit: it appears to have worked correctly).
Discussion can continue here:
