Configurar Discourse para desenvolvimento no Fedora Linux
This guide has been tested against a fresh install of Fedora 31 and 33, but may work on older versions that also use dnf as the package management tool. This is not an official guide but may be useful for other developers using Fedora. This is largely based on the Ubuntu development guide, with changes for the different packages for dnf. The assumption is that you do not have any of the packages installed already, although most will be skipped by the tooling if it is already installed.
If you’re looking to install Discourse for a production environment, prefer the docker install instructions on github.
Install required system and development packages
sudo dnf update
sudo dnf install -y "@development-tools" git rpm-build zlib-devel ruby-devel readline-devel libpq-devel ImageMagick sqlite sqlite-devel nodejs npm curl gcc g++ bzip2 openssl-devel libyaml-devel libffi-devel zlib-devel gdbm-devel ncurses-devel optipng pngquant jhead jpegoptim gifsicle oxipng
Install required npm packages
sudo npm install -g svgo pnpm
Install and setup postgres
sudo dnf install postgresql-server postgresql-contrib
sudo postgresql-setup --initdb --unit postgresql
sudo systemctl enable postgresql
sudo systemctl start postgresql
sudo -u postgres -i createuser -s $USER
Install and setup redis
sudo dnf install redis
sudo systemctl enable redis
sudo systemctl start redis
Installing rbenv, ruby-build, and ruby
git clone https://github.com/rbenv/rbenv.git ~/.rbenv
cd ~/.rbenv && src/configure && make -C src
~/.rbenv/bin/rbenv init
printf 'export PATH="$HOME/.rbenv/bin:$PATH"\n' >> ~/.bashrc
printf 'eval "$(rbenv init - --no-rehash)"\n' >> ~/.bashrc
source ~/.bashrc
git clone https://github.com/rbenv/ruby-build.git "$(rbenv root)"/plugins/ruby-build
# confirm the install is correct
curl -fsSL https://github.com/rbenv/rbenv-installer/raw/main/bin/rbenv-doctor | bash
rbenv install 2.7.1
rbenv global 2.7.1
rbenv rehash
Install Ruby dependencies
gem update --system
gem install bundler mailcatcher rails
Clone Discourse code
git clone https://github.com/discourse/discourse.git ~/discourse
cd ~/discourse
Install Discourse dependencies
bundle install
pnpm install
Create the required databases and load the schema
bundle exec rake db:create db:migrate
RAILS_ENV=test bundle exec rake db:create db:migrate
Test installation by running the tests
bundle exec rake autospec
Run the application
bundle exec rails server
You should now be able to see the Discourse setup page at http://localhost:3000.
For further setup, see the existing official install guides.
This document is version controlled - suggest changes on github.
27 curtidas
Em Instalando rbenv, ruby-build e ruby, o URL para o script rbenv-doctor não está mais funcionando (aparentemente o branch foi renomeado de master para main), o comando correto agora é:
2 curtidas
Obrigado pelas informações @nicolas-jaussaud, atualizei o OP.
Para constar, agora prefiro usar chruby e ruby-install em vez de rbenv.
2 curtidas
Tive um problema ao executar bundle install, pois o Fedora agora desabilita o transporte de arquivos por padrão.
O erro ocorre ao tentar instalar o gem sprockets e termina com a mensagem:
transport 'file' not allowed
Não sei qual é a maneira correta de fazer isso, mas você pode permitir temporariamente o transporte inseguro:
git config --global protocol.file.allow always
# execute a configuração do discourse aqui
git config --global protocol.file.allow never
Depois disso, encontrei um erro como este ao executar db:migrate:
At /home/hhyyrylainen/Projects/discourse/lib/site_setting_extension.rb:199:in `public_send`
Deprecation notice: `SiteSetting.enable_personal_messages` has been deprecated. Please use `SiteSetting.personal_message_enabled_groups` instead. (removal in Discourse 3.0)
#<Thread:0x00007f94c3342600 /home/hhyyrylainen/Projects/discourse/lib/scheduler/defer.rb:83 run> terminated with exception (report_on_exception is true):
/home/hhyyrylainen/.gem/ruby/3.2.0/gems/activerecord-7.0.4.3/lib/active_record/connection_handling.rb:309:in `connection_pool': ActiveRecord::ConnectionNotEstablished (ActiveRecord::ConnectionNotEstablished)
	from /home/hhyyrylainen/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rails_multisite-4.0.1/lib/rails_multisite/connection_management/rails_61_compat.rb:8:in `current'
	from /home/hhyyrylainen/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rails_multisite-4.0.1/lib/rails_multisite/connection_management.rb:115:in `current_db_hostnames'
	from /home/hhyyrylainen/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rails_multisite-4.0.1/lib/rails_multisite/connection_management.rb:111:in `current_hostname'
	from /home/hhyyrylainen/Projects/discourse/lib/discourse.rb:232:in `handle_job_exception'
	from /home/hhyyrylainen/Projects/discourse/lib/scheduler/defer.rb:114:in `rescue in do_work'
	from /home/hhyyrylainen/Projects/discourse/lib/scheduler/defer.rb:113:in `do_work'
	from /home/hhyyrylainen/Projects/discourse/lib/scheduler/defer.rb:85:in `block (2 levels) in start_thread'
	from /home/hhyyrylainen/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rails_multisite-4.0.1/lib/rails_multisite/connection_management.rb:79:in `with_connection'
	from /home/hhyyrylainen/Projects/discourse/lib/scheduler/defer.rb:96:in `do_work'
Parece que aconteceu após a migração terminar, então como não consegui descobrir como consertar, ignorei, mas felizmente meu site de desenvolvimento parece estar funcionando.
Para o ambiente de teste, não obtive o mesmo erro, mas obtive um erro sobre a falta de oxipng, que não parece estar disponível como um pacote Fedora.
Depois disso, não tive mais problemas, tudo ainda funcionava mais ou menos bem no Fedora 38. Embora, eu tivesse instalado o rbenv anteriormente usando outras instruções de configuração.
Executando bundle exec rake autospec, obtive algumas falhas de teste (135), mas parece que tenho uma configuração de desenvolvimento quase funcional.
2 curtidas
Consegui fazer a versão Dev funcionar há algum tempo, mas a versão de Produção foi muito difícil para mim. .
Acabei de seguir este guia para instalar no Fedora 40 Workstation, tive que adicionar oxipng às instalações da distribuição.
sudo dnf install oxipng
3 curtidas
Obrigado por nos informar, atualizei a documentação neste commit: docs/fedora-setup: include oxipng package (#14) · discourse/discourse-developer-docs@eb51e54 · GitHub.
1 curtida
Estou travado após a instalação hoje no Fedora 41 com o seguinte problema quando me conecto a localhost:3000 e clico em registrar:
“nenhum e-mail de administrador foi definido durante a configuração”; a mensagem fornece como adicionar um e-mail de administrador.
Falhei em adicionar com sucesso uma conta de administrador seguindo este procedimento por causa de 2 erros ao usar ./launcher enter app:
1° O primeiro erro resolvido foi: o arquivo app.yml não está presente → Copiei o sampleapp.yml da pasta sample para a pasta do contêiner, depois modifiquei para adicionar endereços de e-mail, então fiz a reconstrução com /var/discourse/launcher rebuild app
2° O segundo erro não foi resolvido:
Resposta de erro do daemon: Nenhum contêiner encontrado: app
Se eu usar os comandos rake para criar um administrador, ele me diz que nenhum rakefile foi encontrado
Alguém pode ajudar?
Esta instalação não usa docker, então você não pode entrar em um contêiner.
Tente criar um administrador a partir da pasta Discourse com este comando:
bin/rails admin:create
1 curtida
Olá Coconut, você é rápido para responder e eficiente, muito obrigado!
O comando retorna gem bunder missing, que eu instalei com gem install bundler -v 2.6.2 e então pude aplicar sua solução com sucesso!
2 curtidas
Acabei de tentar executar uma instalação local e encontrei problemas com o pgvector. Isso é no Fedora 42 e Postgres16. A versão empacotada do pgvector é 0.6.2 e parece que preciso compilar do código-fonte para obter uma mais recente.
Em seguida, encontrei conflitos ao tentar compilar o pgvector, que parece exigir o pacote postgresql-private-devel que tinha solicitações conflitantes com o libpq-devel.
Resolvido por:
  • sudo dnf install postgresql-server-devel --allowerasing
  • Compilar pgvector
  • Verificar a versão instalada
    sudo -u postgres psql discourse_development -c "SELECT * FROM pg_available_extensions WHERE name = 'vector';"
  • sudo systemctl restart postgresql
2 curtidas
