This is an old theme!
If you are using this theme or are interested in it please use Pyx's Modern Theme instead. No updates are being made to this theme.
darkpixlz’s Modern Theme
This is a theme with rounded corners, a lot of blur, a consistent look, and it’s very custom to fit with your forum.
!!WARNING: Some screenshots may be out of date, if they are, then this post is a wiki, feel free to edit!
This theme is made for dark schemes. It supports light ones, but some things may be broken.
Screenshots:
There’s also a tile version, but I couldn’t find a good use of it for this post.
I’m editing this topic but I have to reply and Discourse wont let me save the draft - this will be edited with more screenshots soon.
This theme supports most major plugins.
It also will not come with a different color pallet for now, look out for that in the future.
Have any ideas? Let me know on here!
Settings
Is Cursor Active: Allows the cursor to change states.
Example:
Disabled (default):
Enabled:
Background Image: Changes the background image.
Is Background Blurred: Enables the background blur.
Background Type: Toggle between a tile background and a scale background.
Tile Size: Changes the tile size, to apply to tile backgrounds.
Staff Tag: Enables a “STAFF” tag next to admin and moderator’s names. Enabled by default
Plugins + components known to cause issues
- Full Width Component
- (possibly) All Ad Plugins
Other notices
- I don’t recommend adding custom backgrounds to things that aren’t settings (like tags), as it will cause incompatibilities or bugs.
- Chrome and iOS are known to have issues with background blur in some places
- “Latest” and “Top” pages have known issues on mobile
- Theme Creator Preview does not work correctly due to colors
- While light schemes are possible, it might break some things and make them hard to read.
| Preview | Theme Creator | |
| Repository | GitHub - pyxfluff/darkpixlz-Modern-Theme · GitHub | |
| Install Guide | How to install a theme or theme component | |
| New to Discourse Themes? | Beginner’s guide to using Discourse Themes |
Install this theme
Release Notes
DarkPixlz's Modern Theme - #65 by darkpixlz
