Minimizing Maintenance on Theme Customizations
Discourse is highly customizable, enabling you to modify almost any aspect of its appearance through themes.
To maintain compatibility with ongoing Discourse updates and new features, all themes require occasional maintenance. The frequency of maintenance depends on the customization complexity and type. You can minimize maintenance efforts for your theme by following these guidelines:
  • Check for official themes or theme components that match your desired functionality. These are updated alongside Discourse. These can also serve as examples of how to approach your own customizations.
  • Replace interface text using the admin → customize → text feature by searching for the specific text and updating it there.
  • Theme CSS is additive, allowing you to override default styles without editing them directly. This approach improves CSS maintainability and minimizes conflicts with updates.
  • Use a version control system like Git with GitHub, GitLab, or Bitbucket for tracking changes. While the HTML and CSS editor at admin → customize → themes is convenient for minor adjustments, version control systems can make it easier to track and troubleshoot more complex changes.
  • For advanced customizations, create independent modules for new functionality and integrate them through plugin outlets. Discourse uses Ember.js, so building Ember components is ideal. This method isolates custom functionality, reduces maintenance, and helps avoid conflicts with Discourse updates.
Overriding default Discourse JavaScript and HTML templates within a theme should be a last resort, as these changes are more likely to be incompatible with Discourse updates, can be difficult to troubleshoot, and are more prone to errors resulting in downtime.
For more information on using and building Discourse themes, feel free to ask questions on our Meta community, and take a look through our theming guides:
This document is version controlled - suggest changes on github.
