I want a theme component for Discourse that includes:
Search Menu:
• The search menu should allow filtering based on multiple Group Tags.
• Within each Group Tag, users should be able to select multiple tags.
AND Logic for Group Tags:
• The filter should apply an AND logic between selected Group Tags, not OR. This means that results must match all selected tags across different groups.
Display Results in a Table:
• The filtered results should be displayed in a table format.
• Each Group Tag should correspond to a column in the table, making it easier for users to compare results.
