The syntax highlighter doesn't support `--word-diff`s
The discussion addresses an issue with the syntax highlighter not supporting --word-diff in git diffs. rokejulianlockhart provides an example of the output from git diff --word-diff, which includes highlighted changes using {+...+} and {...-} markers. sam suggests reporting the issue to highlight.js on GitHub, as it relates to the default diff implementation. rokejulianlockhart acknowledges the suggestion, and sam adds that a theme component could potentially handle the diff, though it’s not currently possible.
As an example, git diff --word-diff old.sh new.sh produces:
diff --git a/old.sh b/new.sh
index 18237f5..208b37d 100644
--- a/old.sh
+++ b/new.sh
@@ -1,8 +1,22 @@
{+GRUB_TIMEOUT="15"+}
{+  # Original:+} GRUB_TIMEOUT=5
GRUB_DISTRIBUTOR="$(sed 's, release .*$,,g' /etc/system-release)"
  {+# Original: Identical+}
GRUB_DEFAULT="saved"
GRUB_DISABLE_SUBMENU="true"
  {+# Original: GRUB_DISABLE_SUBMENU=true+}
{+GRUB_TERMINAL_OUTPUT="gfxterm"+}
{+  # Original:+} GRUB_TERMINAL_OUTPUT="console"
GRUB_CMDLINE_LINUX="rd.luks.uuid=luks-31b94f4a-915c-47ee-af7a-a7c948b23cf4 {+quiet"+}
{+  # Original: GRUB_CMDLINE_LINUX="rd.luks.uuid=luks-31b94f4a-915c-47ee-af7a-a7c948b23cf4+} rhgb quiet"
{+GRUB_DISABLE_RECOVERY="false"+}
{+  # Original:+} GRUB_DISABLE_RECOVERY="true"
{+GRUB_ENABLE_BLSCFG="true"+}
{+  # Original:+} GRUB_ENABLE_BLSCFG=true
  {+# Reason: https://discussion.fedoraproject.org/t/missing-boot-entries-with-grub-enable-blscfg-true/70805/3+}
{+GRUB_GFXMODE="2560x1600,auto"+}
{+  # Original: None+}
{+GRUB_DISABLE_OS_PROBER="true"+}
{+  # Reason: https://github.com/MaddieM4/os-prober/issues/5#issue-777438588+}
A real-world usage is:
I think it is best reporting this to hljs on GitHub, given it is an issue with the default diff implementation:
Discourse really can not control this easily, we simply pull the changes from upstream.
@sam, thanks. In retrospect, this shan’t be possible:
https://github.com/highlightjs/highlight.js/issues/2911#issuecomment-739586916
Technically a theme component can ship a different grammer, it is complicated but doable imo.
