In a Support discussion titled “How to enable (3+ level) nested subcategories,” Salma_Quraishi requests support for deeper category nesting (up to 5 levels) to better organize their community forum. NateDhaliwal responds by referencing a prior solution involving server access and setting SiteSetting.max_category_nesting = 3 via Rails console, suggesting the feature already exists. pfaffman humorously cautions against trusting the solution and recommends using tags instead for better organization. awesomerobot clarifies that while the max_category_nesting setting exists, it is capped at 3 levels and does not support deeper nesting. The thread highlights a gap between user needs and current platform limitations, with community members offering both technical workarounds and alternative organizational strategies.
I run a community that would greatly benefit from allowing more than one level of subcategory (e.g., sub-subcategories). Our use case is for a community forum and the current structure is restrictive because we have few sub categories to be created upto 5.
If 3 or even 5 levels of nested categories could be supported, it would allow us to build the forum. I’ve seen similar requests from others and would love to see this feature prioritized, even as a plugin.
