\\\1 In Code Block Fails
I cannot seem to get \\ 1 to render without a space or some other character between "\" and “1”.
Adding three or four slashes doesn’t seem to do the trick.
Using indentation to create a block doesn’t seem to do the trick.
The issue exists irrespective of block or inline code, syntax highlighting or not.
2 « J'aime »
I will try to fix this, the bug is with the highlight engine, let me check.
I tried to fix the bug, i thought it was a problem with the highlighting, but is a markdown bug, as @sam says, they will use a new engine for Discourse, you will have to wait till then.
1 « J'aime »
I’ll wait. Thanks for trying!
1 « J'aime »
This now works: \\1
`\\1`
:hugs:
2 « J'aime »
