Discourse Mangling Text in a Code Block
Hey Folks,
I’m posting AppleScript on the Keyboard Maestro forum using a code-block.
A user reported a compile problem with my code.
Rendered by Discourse:
set foundList to cng("<td class=\"pricesens\">.+title=[[:punct:]](price sensitive)[[:punct:]]>", "\\1", foundList) of me
What should be:
Double-Quote-Backslash-Backslash-1-Double-Quote
Is rendering as:
Double-Quote-Backslash-BackTick-Double-Quote.
“\\1”
Using a <code></code> block on the forum I can get the few characters above to show up correctly by adding a backslash, but it the code-block doesn’t like my complete line of code.
Using <pre></pre> tags doesn’t help on the forum, although it works perfectly well in a normal html page.
Code-blocks should be completely unadulterated, so I conclude this is a bug.
Regards,
Christopher Stone
Seems like a bug, yes:
Indented 4 spaces
As a code block
The two backslashes in front of the 1 are not rendering correctly. You could try it on Babelmark as well…
Minimal repro
\\1
\\1
\\1
\\1
Broken in all code version.
Hey Folks,
This bug is still not fixed.
Code rendering needs to be bombproof reliable…
-Chris
They aren’t on commonmark yet, and this is tagged to be reviewed when they move to it.
And … it now works!
\\1
\\1
\\1
Yay
\\1
`\\1`
    \\1
It will take a bit till this is rolled out but new engine fixes it:
