Was using MediaSpy (forum which also uses Discourse), then after a few posts, I saw “1 Reply”. When I try to click on it, it disappears. I tried to refresh the page but it wasn’t there. The bottom was most likely relevant to the post which has the “1 Reply” indicator disappeared.
AzeemHadzrie reported an issue with the “1 Reply” indicator disappearing after trying to click on it. CocoQuark suggested reproducing the issue on meta.discourse.org or try.discourse.org to determine if it’s a local problem and asked if the issue was reported to the relevant authorities. Moin shared a screen recording of the issue and noted that the indicators disappear without clicking, possibly due to posts being at the preload border, loading some posts before others. Moin believes the indicator disappears once the posts below are loaded.
Hi,
Can you reproduce the issue here on meta.discourse.org, or on try.discourse.org? If you can’t, the issue is likely to be on their end.
Did you report the issue to them?
I can
Seems they now disappear without clicking them.
I think the indicator isn’t suppressed until the post below is loaded. Once the posts below are loaded, the indicator disappears.
