Moduli di esempio
:discourse2: Summary Placeholder Forms will let you build dynamic documentation, by creating a form that replaces any occurrence of a =PATTERN= in your post with the value from a text or selectable input field.
:eyeglasses: Preview Preview on Discourse Theme Creator
:hammer_and_wrench: Repository Link https://github.com/discourse/discourse-placeholder-theme-component
:open_book: New to Discourse Themes? Beginner’s guide to using Discourse Themes
Install this theme component
Features
Add placeholders to posts in this format:
[wrap=placeholder key=NAME description="Your name"][/wrap]
[wrap=placeholder key=COUNTRY default=US defaults=FR,DE,US,CN,AU,CA][/wrap]
Your email: =NAME=-=COUNTRY=@example.com
And this will result in:
This is used in mailing list
Your email: =ZNAME=-=ZCOUNTRY=@example.com
As seen above, text inside the wrapper will be used as a long description.
[/wrap]
Available keys
  • key: The key that should be replaced in your post
  • default/defaults: default value(s)
  • description: a placeholder text for the input
Examples
# create a new plugin
rails g plugin =PLUGIN_NAME=
cd plugins/=PLUGIN_NAME=
We use it to create runbooks, howtos and reusable templates (it will work in code blocks). Please share your use cases!
Settings
Translation Default
toolbar.builder Add Placeholder
builder.errors.no_key A key is required.
builder.title Add Placeholder
builder.insert Insert
builder.key.label Key
builder.key.description The =Key= to be replaced in the post.
builder.description.label Description
builder.description.description Description displayed on input with no value set.
builder.values.label Default value(s)
builder.values.description Optional value(s) for your placeholder, if multiple values are defined, a select will be used.
:discourse2: Hosted by us? Theme components are available to use on our Standard, Business, and Enterprise plans.
65 Mi Piace
The big issue with math handling like this, is that you need to eval() and eval is unsafe, so you need to use some lib which provide a safe eval with a limited subset of the real eval. I’m unsure we want all this complexity for such a rare case.
6 Mi Piace
I tried ! and that would be a neat composer-preview-redux-in-OP kind of thing but… :pensive: I must be missing something, if I understand correctly the Reply Template component takes the raw and looks for “replacers”, but the Placeholder Forms component decorates the cooked?
What I’m trying to do is ease my users into adding some quizz Q&As in a topic, with minimal technical friction, clicks or even key strokes, :heavy-sigh: :roll_eyes:
[wrap=placeholder key="question" description="question"][/wrap]
[wrap=placeholder key="réponse" description="réponse"][/wrap]
[wrap=template key="template-spoiler" action="reply" tagsList="#qui, #quand, #où, #comment"]
## Question
=question=
### Réponse
[spoiler]
=réponse=
[/spoiler]
*Étiquette(s) ?*
[/wrap]
which gives
so far so good, but unfortunately, the placeholders =question= and =réponse= are kept in the composer when hitting the template button
Yes I’m not sure what I was thinking when I wrote this… I probably had a different use case in mind, but can’t remember.
It can’t work this way for sure. I will think a little bit about this… Both theme components were experiments at the time and might deserve better treatment as people have been using it quite frequently.
7 Mi Piace
Thank you !
happy lets go GIF by Shalita Grant
3 Mi Piace
:grin: I don’t know what’s cookin’ in the chef kitchen, but as I usually stuff myself with pistachios or whatnot while waiting, I managed to make it work (for my specific use of course as I’ve almost no idea of what I’m doing, but hey… :sweat_smile: )
4 Mi Piace
Ideally I would like to be able to let admin define their own replacers, but eval is risky (and not even possible with a secure csp) so I’m not sure how I could achieve this…
3 Mi Piace
First of all - great and really helpful theme component.
But I think I found a bug. If I use a placeholder in a code snippet, that contains backticks (`), it is not working. An example is a SQL code snippet:
DELETE FROM `=TABLENAME=`
WHERE id NOT IN(
        SELECT
            id FROM (
                SELECT
                    id FROM `=TABLENAME=`
                ORDER BY
                    id DESC
                LIMIT 20
) subquery);
TABLENAME gets never replaced (if there is a TABLENAME placeholder).
Sarebbe bello se includesse anche delle condizioni simili a Jinja2. In modo che, ad esempio, qualcuno possa creare una chiave red e associarla all’icona :red_circle:, orange verrebbe associata a :orange_circle:. Ma posso farne a meno ovviamente, sarebbe stato bello avere queste condizioni di test.
Adoro questo componente. :star_struck:
"E vivi davvero del =NOUN_1=? Che vita =ADJECTIVE_1=! "
“Ne vivo e con esso e su esso e in esso,” disse =PERSON_1=. “È mio fratello e mia sorella, e zie, e =NOUN_2=, e cibo e bevande, e (=ADJECTIVE_2=) =VERBING_1=. È il mio =NOUN_3=, e non ne voglio altro. Ciò che non ha non vale la pena =VERBING_2=, e ciò che non sa non vale la pena =VERBING_3=. Signore! i =NOUNS_1= che abbiamo passato insieme! Sia in inverno che in estate, in primavera o in autunno, ha sempre il suo =NOUN_4= e i suoi =NOUNS_2=. Quando a febbraio ci sono i =NOUNS_3=, e la mia =NOUN_4= e la cantina sono piene di =NOUN_5= che non mi servono, e il =COLOR_1= =NOUN_6= scorre vicino alla mia migliore finestra =NOUN_7=; o ancora quando tutto si abbassa =ADVERB_1= e mostra chiazze di =NOUN_8= che profumano di =FOOD_1=, e i =NOUNS_5= e i =NOUNS_6= intasano i canali, e posso =VERB_1= circa =MOISTURE= =NOUN_9= su gran parte del =NOUN_10= e trovare fresco =FOOD_2= da mangiare, e cose =ADJECTIVE_3= che la gente ha lasciato cadere dai =NOUNS_7=!”
Originale tratto dalla versione Standard Ebooks di The Wind in the Willows, disponibile per lettura online (cerca By it and with it).
10 Mi Piace
Ciao :wave:
Grazie per questo componente :heart: Corrisponde perfettamente a ciò che sto cercando di ottenere ora. In realtà, il mio primo pensiero è stato che sarebbe fantastico se potesse essere combinato con il componente Reply Template. Ma sfortunatamente non è possibile, come spiegato nei post precedenti. :confused:
Ho trovato una soluzione per usarlo come modello, funziona con link a nuovi argomenti e link a nuovi messaggi personali.
Ecco come l’ho fatto:
  1. Crea un modulo segnaposto (per semplicità uso l’esempio nell’OP)
La tua email: =NAME=-=COUNTRY=@example.com
  1. Crea un link a un nuovo argomento:
    Ho impostato nel link:
  2. categoria
  3. titolo
  4. corpo
Se vuoi aggiungere righe vuote, usa \ in modo che non interrompa il link o per renderlo invisibile puoi usare   che aggiungerà uno spazio nella nuova riga. Sarà parte del modello e creerà una riga vuota,
<a href="https://meta.discourse.org/new-topic?category==CATEGORY=&title=This is a topic created by =NAME=&body=Hello :wave:
&nbsp;
This is a test topic... Let's see the placeholder form.
Your email: =NAME=-=COUNTRY=@example.com">Usa il modello come nuovo argomento</a>
  1. Crea un’anteprima dell’argomento
Categoria selezionata
=CATEGORY=
Titolo dell’argomento
Corpo dell’argomento
Hello :wave:
This is a test topic… Let’s see the placeholder form.
  1. Crea il pulsante “Usa il modello come nuovo argomento” (nell’esempio sopra questo è un link, puoi trasformarlo in un pulsante)
Crea un elemento [wrap] da questo testo. Questo lo rende disponibile per essere indirizzato con CSS e stilizzato. Lo aggiungo qui sotto.
&nbsp;
Your email: =NAME=-=COUNTRY=@example.com">[wrap=template-button]Usa il modello come nuovo argomento[/wrap]</a>
Styling [wrap=template-button]
qualcosa come :arrow_down_small:
Common / CSS
[data-wrap="template-button"] {
  background: var(--tertiary);
  color: var(--secondary);
  border-radius: var(--d-button-border-radius);
  padding: 0.5em 0.65em;
  transition: background 0.25s;
  &:focus,
  &:hover {
    background: var(--tertiary-hover);
Il pulsante del modello apparirà così :arrow_down_small:
template-button
Demo
Spero che questo piccolo tutorial aiuti qualcuno che ha bisogno di qualcosa di simile :slightly_smiling_face:
Modifica: Ho impostato un selettore di categorie che aggiunge la possibilità di creare argomenti in diverse categorie.
Controlla la versione raw di questo post…
8 Mi Piace
Fantastico Don, grazie. Questo soddisfa molto bene una delle mie esigenze :slight_smile:
2 Mi Piace
Qualcosa da notare è che i blocchi di codice a volte causano problemi:
usermod -aG sudo =USERNAME=
In questo caso, highlight.js presume che si tratti di Java e converte il blocco di codice in:
<code>
  usermod -
  <span class="hljs-type">aG</span>
  <span class="hljs-variable">sudo</span>
  <span class="hljs-operator">=</span>
  USERNAME=
</code>
Riesco a risolvere segnalando che si tratta in realtà di un comando shell:
    ```shell
Ciò si traduce in:
Se tutto il resto fallisce, text impedisce a highlight.js di interferire con i placeholder.
Una soluzione più generale (che Meta Discourse deve utilizzare) è cambiare l’impostazione default code lang da auto a plaintext o qualcosa di simile. :wink:
Non che importi molto, ma usare java è un modo per evitare che il placeholder si espanda quando si vuole scrivere sui placeholder.
1 Mi Piace
Puoi controllare il link di anteprima? Mi sembra che sia rotto.
1 Mi Piace
Questa è una funzionalità straordinaria e posso vederne molti usi.
Tuttavia, nella nostra risposta, è possibile nascondere =(nome)= finché l’utente non inizia a digitare nella casella di testo? Ritengo che gli utenti (specialmente quelli nuovi) potrebbero non capirne lo scopo, o che sembri una formattazione errata.
Penso di averne trovato uno funzionante (:crossed_fingers: :slight_smile:)
https://discourse.theme-creator.io/theme/Discourse/placeholder-forms
L’ho aggiunto anche a try.discourse.org così puoi giocarci più a fondo. :+1:
1 Mi Piace
Forse potresti inserire un valore predefinito che verrà visualizzato al suo posto.
1 Mi Piace
Ha funzionato! Grazie!
2 Mi Piace
Questo workaround non sembra più funzionare.
Ci sono altre opzioni per combinare reply-template e placeholder-forms?
4 messaggi sono stati divisi in un nuovo argomento: I link non funzionano nei moduli segnaposto
