Advanced Search Banner
:warning: Note
We are planning to deprecate support for this theme component soon and advise you to use the welcome banner feature instead.
:discourse2: Summary Advanced Search Banner puts a search bar along with optional headline and subhead text in a banner above the main topic list navigation.
:eyeglasses: Preview Preview on Discourse Theme Creator
:hammer_and_wrench: Repository Link https://github.com/discourse/discourse-search-banner
:open_book: New to Discourse Themes? Beginner’s guide to using Discourse Themes
Install this theme component
Features
By default, this banner appears on all top-level topic pages (latest/new/unread/top/categories… anything in the top menu site setting) but it can also be set to only display on a community’s homepage.
Settings
Name Description
show on This determines which pages the banner appears
plugin outlet Where on the page the banner will appear
background image light Background image for the banner on light color palettes
background image dark Background image for the banner on dark color palettes
tile background image Repeat the background image
show for Who can see the Search Banner (logged in, logged out, or both)
special style Optional variations that change the appearance of the search banner
Translation Default
search_banner.headline Welcome to our community
search_banner.subhead We’re happy to have you here. If you need help, please search before you post.
search_banner.search_button_text
To omit one from display, leave the field blank.
Custom styling
The HTML element gets a class named .display-search-banner wherever this banner appears, and the banner itself is wrapped with the .custom-search-banner class, so with some CSS you should be able to customize the appearance of this banner however you see fit.
Future enhancements
  • Add an option to enable the banner in specific categories
Credits
:sparkling_heart: This very heavily borrows from @angusPavilion Header Search Theme Component
:discourse2: Hosted by us? Theme components are available to use on our Standard, Business, and Enterprise plans.
「いいね!」 83
[PAID] New search bar
Bringing popular features to Discourse: Header search, welcome banner, and category icons / emoji
Elementary Layout Component
Searching for users on mobile
New Theme: Tag-Pages Navigation
How to add links on home page menu to other site?
Adding Search option
Header search in custom header
Can't find how to localize a theme component
Mint Theme
Creating and installing plugins?
Bug with "search_banner.search_button_text" shown in search banner theme component
Search banner requires login
Help Needed for Installing Meta Branded Theme
Banner Featured Links
Search section like on Reddit?
How do I edit "Welcome to our community" and tagline on the Homepage?
Anything wrong with this component?
User card out of alignment
Search Banner image cuts off on smaller screens
Where to find search bar in our settings?
Fully Theme
Welcome Banner components
What plug-in or customization for this header?
Custom Platform
Homepage header, how to add?
How can I make the home page similar to this one?
Theme or Custom CSS on Monday’s Discourse Instance?
Community not displaying correctly - new problem - help!
Christmas Decoration Component :christmas_tree:
We're upgrading our icons to Font Awesome 6!
Search for and/or filter topics in a category using text search
Forum search bar not showing up
3.5.0.beta9: Improving color management, core welcome banner, and staff action log filters
Translations of theme component sample texts
Making my discourse site look a certain way
How can I change the HTML template of advanced search?
How to change the header text on the title page
Advanced Header Search
How to make a custom search bar?
Bug in Search banner theme component
Simple modifications
How can I achieve these header and footer customisations?
Meta Branded theme and all categories header
Search in this topic filter issue with Search banner TC
Customizing your site with existing theme components
I’ve updated the theme component to add some new settings:
show on — this determines where the banner appears and has the options
  • top_menu (latest/categories/top/new/unread)
  • homepage
  • all (all pages except the default search page and admin pages)
show for — this determines who sees the banner
  • everyone
  • logged_in
  • logged_out
「いいね!」 17
コンポーネントにオプションのスタイルを追加するマイナーアップデートを行いました。これにより、タイトルテキストなしの大きな検索バーが表示されます。
これは新しい「スペシャルスタイル」設定で有効にできます。これを行うのは、少し追加のCSSを有効にするだけです。
将来的には、さらにオプションを追加する可能性があります!
「いいね!」 8
このアドオンの「ようこそ」テキストの色を変更するにはどうすればよいですか?
「いいね!」 1
それに対する設定はありません。ただし、CSSで追加できます。
以下をテーマまたは新しいテーマコンポーネントに追加し、必要に応じて変更してください。:+1:
.search-banner > .custom-search-banner  {
    /* title */
    h1 {
        color: #286989;
    /* description */
    p {
        color: #286989
「いいね!」 3
どうもありがとうございます!
「いいね!」 2
検索アイコンを非表示にする方法はありますか(CSSまたはその他の方法を使用)? このコンポーネントと組み合わせて使用すると、検索アイコンが重複するという問題が発生しています: Advanced Header Search - #56 by RBoy
「いいね!」 1
.search-input .search-icon:first-child {
  display: none;
検索アイコンは1つだけ表示されるはずです。ただし、検索バナーとヘッダー検索を同時に使用すると、UXに悪影響があることは申し添えておきます。
どちらか一方のみを使用することをお勧めします。
「いいね!」 4
ありがとうございます!大変参考になりました。
具体的にどのようなUXの悪影響があるのか、詳しく教えていただけますか?
「いいね!」 1
上記の動画で、いくつかの問題点を示しています :slight_smile:
  • 重複する検索ドロップダウン
  • 検索ドロップダウンの奇妙な開閉状態
  • 検索アイコンが、一方の検索入力では高度な検索へのリンクになっているが、もう一方ではそうではない
  • など
「いいね!」 2
承知しました。同じページにない限り、問題ないということですね。
「いいね!」 2
誰か手伝ってくれませんか? Discourseにこのテーマをインストールしましたが、画像が右側の一部で切り取られています。画像が完全に収まるようにするには、サイトのフォントを「より小さい」に設定する必要があります。Discourseのインストールは2つありますが、そのうちの1つでは画像は正常に機能しましたが、もう1つでは画像が切り取られているのはなぜですか?
「いいね!」 2
スクリーンショットを含めることはできますか?これにより、問題を理解するのがはるかに簡単になります。
「いいね!」 2
同じ問題が発生しており、異なるブラウザ/モードで画像の異なる部分が表示されます。画像を非常に幅広くすることで解決しましたが、これにより右側が一部の条件でしか表示されなくなります。しかし、対称的な画像ではそれほど簡単ではありません。おそらく、さらにCSS(thome-component-overwrite を検索せずに)を追加すると役立つでしょう。
一部解決できました。他のテーマのテーマコンポーネントを無効にし、1つだけ残しました。信じられないかもしれませんが、画像はフォントサイズが「normal」で「normal」だったのは、携帯電話のせいで画像の片側しか表示されなかったからです。携帯電話でも完全に表示できるように何かできることはありますか?
こんにちは。
検索バナーとヘッダーの間のスペースを削除する方法はありますか?
「いいね!」 1
こんにちは、新しいテーマコンポーネントでこのCSSを使用できます。
.custom-search-banner-wrap {
    margin-top: 0;
「いいね!」 3
完璧に機能しました、ありがとう!
「いいね!」 2
3件の投稿が新しいトピックに分割されました:検索バナーのサブヘッダーテキストに改行を追加できますか?
Discourse にも私のコミュニティと同じ問題があるようです。検索アンダーレイ (Discover) を覆うオーバーレイが表示されるまでに時間がかかります。
2024-07-05 14.42.23
私のコミュニティでは、さらに顕著です。
2024-07-05 14.49.53
この問題に対する修正策をご存知の方はいらっしゃいますか?オーバーレイの表示を遅延させることで解決できるかもしれません。ユーザーエクスペリエンスが悪化する可能性があります。
「いいね!」 1
