| Summary | Discourse Gifs adds a button to the composer that allows you to search for gifs and easily add the best one to your post. | |
| Repository Link | https://github.com/discourse/discourse-gifs | |
| New to Discourse Themes? | Beginnerās guide to using Discourse Themes |
Install this theme component
Features
After searching you get an infinite scrolling wall of related gifs:
Clicking one one inserts it on your current composer, which looks like:
This is heavily based on a old fork of ReplyGif: Adding reaction GIF easily, so thanks to @cpradio.
The big differences are:
It can use animated webp instead of gifs, so itās a lot more efficient for bandwidth.
It is a theme-component, so it is way easier to install and update.
It offers the choice of Giphy API or the Tenor API.
Infinite Scrolling for results
Resulting gifs are downloaded to Discourse using our native bitrot protection. You can disable this behavior using existing settings if space is a concern.
No need to fiddle with nginx to setup a proxy for HTTPS
Obtaining a Giphy API Key
For the component to work you need to visit Dashboard | GIPHY Developers and click like:
Fill up the form and the API key will be show as:
Obtaining a Tenor API key
Get that key at the official Tenor site: GIF API - Better, Faster & Free | Get Your GIFs with Tenor
After that visit the theme-component page in Discourse and fill up the settings, e.g:
Settings
| Name | Description |
| api provider | Which GIF provider should we use? |
| giphy api key | GIPHY: API key |
| giphy file format | GIPHY: Image format to use. WEBP has smaller files that load quicker while GIF provides compatibility with old browsers. |
| giphy content rating | GIPHY: Content rating for search results. Find more info at https://developers.giphy.com/docs/optional-settings#rating . |
| giphy locale | GIPHY: Language to use on the search. Used to cater search to regional content. Set to your default forum locale. |
| limit infinite search results | Limit the number of GIF results returned as the user scrolls infinitely to prevent API Rate Limiting. |
| max results limit | Tenor & GIPHY: When ālimit infinite search resultsā is enabled, we will search until we get this number of maximum GIF results. Each API call retrieves 24 results, e.g. 240 Max Limit: 240 / 24 = 10 API Calls . |
| tenor api key | Tenor: V2 API Key. Instructions to get one can be found in Discourse Meta - Discourse Gifs . |
| tenor client key | Tenor: (optional) client-specified string that represents the integration |
| tenor file detail | Tenor: Image format to use |
| tenor content filter | Tenor: Content safety level for Tenor results. Find more info in Tenor API Guides . |
| tenor country | Tenor: Two-Letter Country of Origin for the request. Find your country code in Wikipedia - ISO_3166-1 . |
| tenor locale | Tenor: Language to use on the search. Country code (optional) can be provided to differentiate between dialects. |
| Translation | Deafault |
| gif.modal_title | Search GIFs |
| gif.query | Term |
| gif.insert | Insert Selected Images |
| gif.composer_title | Search GIFs |
| gif.no_results | Enter a keyword in the input box above to search for GIFs. |
| gif.bad_api_key | Invalid $api_provider API Key. Site admins, please check your key and/or your $api_provider account. |
| gif.error_rate_limit | We have reached our $api_provider API Rate Limits. Please wait and try again later. If this issue persists, contact your site admin. |
| gif.error_search_too_long | Please shorten your search query to under 50 characters and try again. |
Hosted by us? Theme components are available to use on our Standard, Business, and Enterprise plans.
Check document
Perform check on document:
