The Topic List Author theme component allows the topic author’s avatar to appear in topic list pages and category homepages, with customizable column placement (left, center, right) for desktop and mobile views. The component is now official, with the repository updated to discourse/discourse-topic-list-author. Users have reported issues, including avatar duplication when used with Topic Thumbnails and display inconsistencies on certain category pages. A workaround using CSS has been shared to hide the author column in specific categories, and a suggestion was made to align the component with core behavior when hide_user_profiles_from_public is enabled. The original branch is no longer maintained, and users are advised to use the official repo. Lilly provided guidance on compatibility, while davidkingham noted issues with the old branch. Joe_Brown resolved a layout indent issue with CSS, and Moin suggested improvements. nathank requested category-specific application, with a CSS workaround provided by jrgong.
This theme component makes the topic author avatar appear in topic list pages (ie: /latest /new /unread /top) and the category homepage (if using a category view with topic list).
There are also settings to change where the author column appears for topic list pages - left, centre or right.
This component works with both desktop and mobile views, although the centre avatar placement only shows in desktop view.
Screenshots:
Author avatar in default (center) column placement
yea the refactor possibly makes this component incompatible again. I’ll see if I can come up with a workaround of some sort. probably need to hack some CSS to make these two components work together if it’s possible.
question: why do you use this theme component? it appears as though topic list thumbnails is using the topic author avatars already because it previews from the first post (OP), (although there are a lot of settings in that theme component). Are you wanting this to only apply to specific categories that Topic list thumbnails isn’t using?
This component is now official and the repo link in the OP has been updated. Please use the new repo link to re-install this component to avoid any errors. The old repo will not be maintained going forward and will eventually be archived.
I’m a little slow to respond but unfortunately the old branch isn’t working either. On the categories+latest page it shows the last poster not the author. There’s no chance of making this compatible with Topic Thumbnails now that it’s official?
Would it be possible to make this TC be applied to just specified categories, in the same way as Topic Thumbnails and Topic Excerpts?
Workaround
I’ve found that this CSS (when added to the Desktop tab of a theme component) works nicely for my use-case by turning off the functionality for all of the categories except the one I want it to work in:
