읽기 모드
:discourse2: 요약 **리더 모드(Reader Mode)**는 Discourse 토픽 내에서 집중적인 읽기 경험을 제공합니다
:eyeglasses: 미리보기 Discourse Theme Creator에서 미리보기
:hammer_and_wrench: 리포지토리 https://github.com/discourse/reader-mode
:open_book: Discourse 테마를 처음 사용하시나요? Discourse 테마 사용 입문 가이드
이 테마 컴포넌트 설치
기능
이 테마 컴포넌트는 토픽 타임라인에 “리더 모드” 버튼을 추가합니다. "리더 모드"는 텍스트에 초점을 맞추고 다른 UI 요소를 배경으로 흐리게 만들어 더 집중적인 읽기 경험을 제공합니다. 사용자는 다양한 폰트 선택, 텍스트 크기 및 읽기 너비 조정, 선호하는 배경색 변경 등도 선택할 수 있습니다.
설정
이름 설명
svg 아이콘
:discourse2: 우리가 호스팅을 제공하나요? 테마 컴포넌트는 Standard, Business, Enterprise 플랜에서 사용할 수 있습니다.
25개의 좋아요
I really love option to change font size :smiling_face_with_three_hearts:
Bummer that component is not for mobiles.
6개의 좋아요
Happy to see this officially released :slight_smile: :tada:
Is it possible to match the fonts in reader mode to the font-list of the platform? For example, we’re using Open Sans, but that’s not an option on the font dropdown for Reader Mode. Would be a nice touch to have the same list of fonts to choose from. :slight_smile:
Edit: I’m also noticing that topics which use Discourse TOC, but do not have a reply are not showing the Reader Mode Icon.
You can see an example here:
However as soon as there is at least one reply, the Timeline, ToC and Reader Mode seem to appear as expected.
3개의 좋아요
Am I crazy? I don’t see the icon that is included in the topics’s screenshot:
Probably not!
Just try a different theme (I would recommend default, meta branded or air)
3개의 좋아요
Ah, yep, that solved it. Thank you :slight_smile:
1개의 좋아요
I’ve added it to all the themes now. :+1: Not sure if it was missed off some on purpose but I’ll wait for the complaints to roll in to find out. :slight_smile:
2개의 좋아요
Could you add the function for guests too? Currently it’s only for registered and logged in Users.
An implementetion for mobile also would be great.
Thanks for this great component :slight_smile:
Yes, I also hope that in the next updates this theme component will support user options on the phone.
Reader Mode conflics with Disco TOC
it seems we can’t have both the Table of Content (by DiscoTOC, mandatory for big documents) and Reader Mode (also mandatory for big documents)
4개의 좋아요
이 텍스트를 번역할 수 있을까요?
Screenshot - 23_06_2025 , 09_26_26 a. m.
2개의 좋아요
번역이 가능하도록 변경을 제안했습니다:
https://github.com/discourse/reader-mode/pull/50
수정: 병합되었습니다 :tada: 이제 구성 요소를 업데이트하면 설정 페이지에서 버튼을 번역할 수 있어야 합니다.
4개의 좋아요
완벽해요!!!
정말 감사합니다!!!
2개의 좋아요
