feature request:
separate settings to enable/disable AI bot in DM/channels/topics discussion
problem:
currently, for a persona, it has settings for “allow chat”, “allow mentions”.
if allow mentions, could chat with AI bot in channel, and in topic discussion.
it is not possible to allow AI bot talks in channels, but not in topic discussion…
- allowing AI bot in topic discussion, it is useful, but the topics could be easily flooded with these AI-generated content.
- a reply to the bot’s message triggers the AI bot to reply… this is correct behavior, but folks does not realize it even not meant to do that (should use the reply botton below there), sometimes, it just gets the discussion keep going with joking/irrelevant content.. on and on, bit annoying…
this is good and bad, good for more interactions, bad for too much AI-generated content.
proposed solution
- separate settings to enable AI bot chat in DM/channels/topics,
for our case, like to have AI bot chats only in channels, that is fun and helpful. the content is cleared out in days… - “add quotas so you can throttle it even further” (@sam mentioned this in chat, he might already have some thought on this…)
intopicdiscussion,AIbotshouldonlyresponseswhenmentioned,shouldnotkeepreplyingtoanycomment.
hope this could be considered soon, we 'd like to enable AI bot chat, but too much AI-generate content in topic discussion looks no good…
thanks…
please vote for this request, thanks ! ![]()
