Предстоящие изменения в списке тем — как подготовить темы и плагины
As part of our ongoing quest to standardise the rendering systems across Discourse’s codebase, we’re replacing the implementation of the topic-list.
Previously, this used a ‘raw handlebars’ (.hbr) approach, and could be customized via template overrides and raw-plugin-outlets. The new implementation of the topic-list uses modern Glimmer components, and has been built from the ground-up to to be customizable in sustainable ways.
The new implementation is now available behind the glimmer_topic_list_mode setting.
  • disabled: use the legacy “raw handlebars” topic-list
  • auto: will detect the compatibility of your current plugins and themes. If any are incompatible, it will use the legacy system; otherwise it will use the new implementation.
  • enabled: will use the new topic-list implementation. If you have any incompatible plugins or themes, your site may be broken.
We’ve already updated most of our official themes and plugins to be compatible with the new menu. But, if you run any third-party plugins, themes, or theme components which customize the topic list, upgrading them will be required.
Warnings will be printed in the browser console identifying the source of the incompatibility.
:timer_clock: Roll-out Timeline
These are rough estimates subject to change
Q4 2024:
  • :white_check_mark: core implementation finished
  • :white_check_mark: updating official themes/plugins (in progress)
  • :white_check_mark: enabled on Meta
  • :white_check_mark: published upgrade advice
Q1 2025:
  • :white_check_mark: glimmer_topic_list_mode default to auto; console deprecation messages enabled
  • :white_check_mark: deprecations will trigger an admin warning banner for any remaining issues
  • third-party plugins and themes should be updated
  • :white_check_mark: 1st March - enable the new topic-list for all sites. The default for the site setting will be switched to enabled, but it will still be possible to switch back to ‘disabled’
Q2 2025
  • :white_check_mark: after 1st April - final removal of the legacy mode & associated code
:eyes: What does it mean for me?
If your plugin or theme has any ‘raw handlebars’ files (named .hbr or .raw.hbs) then those will need to be updated for compatibility with the new version. Regular .hbs files for Ember components/routes are unaffected by this change.
Upgrades will also be required if you use modifyClass on component:topic-list or component:topic-list-item.
If your site has any of these incompatible customizations, warning messages will be printed to the browser developer console, including information about which theme/plugin is the cause.
What are the replacements?
Some of the old raw-plugin-outlets have been converted to regular Plugin Outlets. Those can be updated in a 1:1 fashion.
More advanced customizations will need to be assessed on a case-by-case basis. The new topic-list has a number of new APIs for easy and robust customization. Find out more here:
Here are some examples:
:sos: What about other customizations?
If your customization cannot be achieved using the new APIs we’ve introduced, please let us know by creating a new Dev topic to discuss.
:sparkles: I am a plugin/theme author. How do I update a theme/plugin to support both old and new topic list during the transition?
The new plugin outlets are rendered in both the old and new implementations of the topic list. So: when you’ve implemented the new one, simply delete the old raw-plugin-outlet connector.
For DAG-based customizations which replace template-overrides or non-modernized outlets, you will need to maintain both implementations during the transition period.
Once your theme/plugin supports both old and new implementations, you can add this magic comment at the top of all your .hbr files:
{{!-- has-modern-replacement --}}
This will silence the deprecation messages, and allow the new implementation to be used when in “auto” mode.
12 лайков
Sorry to be picky, but doesn’t this really mean something more lke “if your plugin of theme has any ‘raw handlebars’ files that have anything to do with topic-list then they need to be updated”
My raw handlebars files that have to do with other models are going to continue to be fine, right? Or are raw handlebars files going away entirely? (I think they are required for additional models/routes, right?)
3 лайка
“Raw handlebars” means our discourse-specific templates, which have the file extension .hbr (or historically .raw.hbs). We only used this system for the topic-list, and some ‘autocomplete’ internals.
Other .hbs files (e.g. for Ember components, or routes) are unaffected.
I’ll update the OP to make that clearer. Thanks @pfaffman!
Edit: here we go:
1 лайк
Oh. You really did try to make it clear. You explicitly stated the extensions. I don’t think you can make it clearer. I think this one is on me. :person_shrugging:
But maybe adding the extra sentence would have helped me be able to read.
1 лайк
Thanks for sharing. I’ve been afraid of this for a long time and it’s coming…:grimacing: It will not seems to be an easy run… :sweat_smile: But value transformer probably will make it easier.:crossed_fingers:
2 лайка
I believe GitHub - discourse/discourse-topic-excerpts: Add topic excerpts to all topics in the topic list has yet to be updated?
1 лайк
Yup, we still have a lot of official themes/plugins pending upgrade. I’ll extend that bullet point into Q1 in the OP :writing_hand:
1 лайк
thanks! enjoying the developer experience so far! I’lll let you know if TLP brings up any issues when I get to that.
2 лайка
Cool! The official topic-list-thumbnails is one of the ones we have finished updating, so that might serve as a useful reference.
2 лайка
Oh, my bad! @isaac updated topic-excerpts last week: DEV: Update plugin for `glimmer-topic-list` (#34) · discourse/discourse-topic-excerpts@0dd3c6c · GitHub
So it should be working ok under the new topic-list :crossed_fingers:
1 лайк
I’m getting:
Both versions are up-to-date
when adding a column, what is the strategic way to add a sortable column header?
by using:
api.registerValueTransformer("topic-list-header-sortable-column"
in addition to the other transformer?
        "topic-list-columns",
doesn’t appear to do this on its own? :thinking:
cc @isaac. If I had to guess: perhaps the new logic needs updating to handle uncategorised topics?
The transformer you found is to override the sortability of existing columns (e.g. we do it in discourse-calendar to prevent any other sort methods being used when you’re on the chronological topic view)
If you’re adding a new column, then you should ‘just’ be able to define your header using the SortableColumn component. e.g. here’s one in core:
(one thing that’s really nice about the new API is that all the core columns are defined using the same API as you use from themes/plugins!)
2 лайка
yes I noticed that when I did a code search, nice!
1 лайк
Fixed :slight_smile:
2 лайка
Q: Is it possible to assign complete Component to a Cell, not just a <template>?
For example, what if I wanted to display a transparent button in a cell that required some minimal javascript logic?
Yup! Technically, a bare <template> tag is technically creating a “Template Only Component”. Similar to the type of component you get when you drop a bare .hbs file under the components/ directory.
So yes, importing and passing a normal component class will work just the same. It’ll even work with classic components! (although obviously we’d recommend using the more modern Glimmer components).
2 лайка
that’s completely awesome!
that changes … a lot! :exploding_head:
1 лайк
Dumb question, maybe.
But how to apply changes to … mobile topic-list?
1 лайк
For mobile, we have a bunch of new plugin outlets (including wrapper outlets).
Or alternatively, you can use a valueTransformer to force the desktop view everywhere (we do this for topic-thumbnails).
I’m planning to write a more detailed “how to customize the topic list” Developer Guides next week, so will be sure to include that info in there.
4 лайка
