Always-Anonymous Categories Plugin
I had a request from a co-worker to find a way to offer “anonymous Q&A” to our division’s employees. At first blush, Discourse seemed like the wrong tool for the job: anonymous posting seemed anathema to the whole point of fostering open, friendly, but lively discussions. Discourse does have built-in support for anonymous posting, but it’s a global setting. What we needed was a way to restrict anonymous posting to a single category (or a select subset of them). Even better, make anonymous posting automatic, so that users don’t have to think about it (and can’t get it wrong).
Thus was born discourse-anonymous-categories.
This plugin lets you choose individual categories for “always-anonymous” behavior, where all posts and replies automatically use the anonymous pseudonym for the user instead of their actual identity. The user doesn’t have to opt-in, and more importantly, doesn’t need to remember to opt-out when they are done posting.
Here’s what that looks like:
  1. After the plugin is installed, turn on the global setting to enable “always-anonymous” categories:
  2. Then, pick a category (or create a new one) for which you want “always-anonymous” behavior, and turn on the “Force posts to be anonymous in this cateory” setting:
  3. Now, when anyone posts (note that current user is “E”):
  4. They will actually get anonymized:
  5. … like this (note that post is as “anonymous”/“A”):
This plays very nicely with recent versions of discourse-feature-voting, which can be used to anonymously vote on topics. (The votes themselves aren’t anonymous, but the identities of the voters are not currently surfaced through the UI, unlike “Likes”.)
30 лайков
and whether non-registered users to post messages in this category?
Is this plugin still working (it hasn’t been updated since two years)?
2 лайка
Somehow I’m having a hard time making it work on my local environment. I’m gonna do some digging and share back here.
Yes, it still works. I had to delete my tmp folder in order to make it work but I think this is a problem with my local dev installation only (not using docker).
2 лайка
Sadly, the purpose for which this was created no longer exists, so I haven’t given the plugin any love for the last several years. If anyone wants to take over maintenance, I’d be happy to let them!
6 лайков
I have a use for this plugin. How do I get it ‘looked after again’? Non-tech person asking, I’m on Communiteq (formerly DiscourseHosting). @michaeld @RGJ
Do you have a budget for this? If so, posting in marketplace is most likely the best approach :slight_smile:
6 лайков
Are you sure that the plugin is not working correctly anymore?
When I read the posts above it just says it needs a new maintainer but Daniel says “Yes, it still works”
2 лайка
Yes, I agree the post says it needs a new maintainer. I guess that’s what I’m wondering if someone would do. Is that something that comes with my Pro hosting package?
I am runing it on v2.0.0.beta10 +111 and looks like it is working.
I do not have some issues whit my instace
2 лайка
Для сведения: в Docker версии 2.4 при добавлении плагина возникает ошибка 500 сервера при отправке запроса к категории, помеченной как анонимная.
@JaredReisinger переместил это в #plugin:broken-plugin в ожидании вашего расследования. В версии 2.4 я переделал способ работы с анонимными аккаунтами, поэтому, возможно, это сломало плагин.
5 лайков
Как обсуждалось выше, я и @michaeld будем рады взять на себя поддержку этого плагина.
6 лайков
У вас нет ориентировочного времени исправления, да? :wink:
Наверное, где-то в сентябре…
1 лайк
@sam прав: новые изменения, касающиеся анонимных пользователей, сломали плагин. Я уже занимаюсь этим, так как мне это нужно для одного из продуктов нашей компании.
Вот ошибка, которую я получаю в продукте:
NoMethodError (undefined method `create_shadow' for AnonymousShadowCreator:Class) /var/www/discourse/plugins/discourse-anonymous-categories/plugin.rb:76:in `block (2 levels) in activate!'
Она возникает в этой строке:
Попробую исправить и скоро опубликую обновление здесь.
4 лайка
Вот моё быстрое исправление: Updating plugin to work with Discourse v2.4.0.beta2 · danielvlopes/discourse-anonymous-categories@08dda70 · GitHub
Думаю, теперь, когда Discourse лучше поддерживает анонимных пользователей, можно убрать и части с пользовательскими полями (custom_fields), но пока я оставлю это изменение простым.
4 лайка
@JaredReisinger, вы всё ещё поддерживаете этот плагин? Если нет, возможно, @Daniel_Lopes сможет назначить OP здесь, чтобы указать на ветку, и мы сможем выпустить это из #plugin:broken-plugin.
4 лайка
Извините, я знаю, что я не гуру, и у меня не получается это сделать… Не могли бы вы, пожалуйста, написать несколько строк с инструкциями? Спасибо.
