Is there any interested in building a very cut down, minimal “Mini” Discourse that is easily built on ANY distro (my priorities would be Fedora and Alpine) but where we could experiment with some of the chat / social features mentioned in the discussion here:
This article is about the usefulness of containerized application on users desktops. Discourse was never meant to run locally on your laptop along side your browser, but in a server where it’s accessible for your whole team/community.
So I dont understand how it’s relevant for Discourse
While I appreciate the inspiration for this, I honestly think Discourse is reasonably easy to try in a few places, Digital Ocean primary among them. There are some core requirements that make it less easy than, say, almost any PHP-based forum, but that’s a whole other issue that’s not worth getting into here. But I do think Discourse testing is reasonably accessible to people if they’re willing to experiment in Digital Ocean. There is a certain barrier to entry, but I can’t really imagine a good way to address it given Discourse’s core development and hosting approach (RoR, Docker, etc.).
The greater question I have is whether this gets at one of the core reasons that Discourse seems to be less “in the conversation” around modern community platforms. My feeling is the answer is no, and I think there are some basic design and functionality issues that are probably a bigger factor. But I’m curious if you feel otherwise.
I am clearly not making my point very well - as I just said in the other response: ‘However my “Mini” suggestion is for just that - starting from scratch - perhaps with Alpine - and producing distro packages not Docker images . .’
So that’s what you mean. Yes. As you have witnessed, that will be hard to create, maintain, and support. You would likely need someone working close full time to keep it up to date. There are so many pieces that you would need to track, from an intricate nginx configuration (which might actually not be one of the hard parts) to the image processing pieces and those are just the obvious pieces.
The bitnami docker image does that, though, and uses a different rails web engine, so it’s possible, but, as with bitnami, you’ll be on your own to support it.
Why do you think this is a good idea? Do you think that you could do that and reduce the system requirements in some tangible way?
Well I was not confident that my idea would get much support but I thought in the light of the previous discussion about Discourse not being considered for some situations then maybe a re-evaluation and experimentation might be useful - so I thought it was still worth a post. However, I thought such an effort could only be done by starting from scratch - BUT with input from existing Devs about what a core, minimal app might need.
I still feel a smaller, lighter and simpler app / package could be useful for smaller shops.
In the unlikely situation that others thought the idea was worth pursuing, I would help with the exercise as much as I could of course!
I indeed don’t have the slightest idea what you want to do. I thought I did but it’s getting more and more confusing.
You want to “start from scratch” but also a “cut down” version. You want to build it easily on any distro and make it simpler at the same time. And you quote an article that talks about how hard it is to deploy apps on Linux Desktop that discusses start up times and graphics drivers, which all seem pretty irrelevant to me.
For now I am sticking to my first response (which has been ignored so far)
Discourse isn’t a desktop application, it is intended to be installed on a server and connected to by remote clients via a browser. You continue to elaborate on how you think discourse could be pared down, but haven’t given a use case as to why.
What’s the purpose of installing discourse on a desktop distro. Which scenario isn’t supported by the current installation?
Discourse can run on a $5/mo VPS or a $35 SBC over most domestic internet connections. How much smaller does it really need to be?
Are you proposing this work as a way to help address the “Discourse not being mentioned in conversation” problem (e.g. by making it more accessible for more people to try it)? Or is your intention different than that? I must say I don’t entirely understand your actual goal, separate from “make Discourse easier to setup on multiple distros”. By which I mean, I don’t understand what broader goal that would accomplish, what greater need is being served. Greater potential for experimentation?
