הוסף קבוצות לעמוד /about
סיכום מבוסס בינה מלאכותית
A discussion about a Discourse theme component that adds groups to the /about page. awesomerobot created the component, which allows admins to display additional groups with settings for member count, capitalization, and ordering. Users Don, Richie, and tobiaseigen provided feedback, requesting features like using group full names instead of slugs, fixing capitalization inconsistencies, and aligning member display with the main admin/moderator section. awesomerobot implemented several updates, including full name support, better capitalization, and an ordering setting. tobiaseigen suggested moving the feature to core due to limitations like missing config UI and styling inconsistencies. Richie shared CSS workarounds to hide admins from trust level groups, while Don suggested consistent member ordering. Heliosurge proposed expanding the component to improve the group page. Richie reported a visibility bug where non-admins couldn’t see certain groups, which awesomerobot clarified was due to group visibility settings. one1 proposed a solution for handling hidden groups. The thread highlights community collaboration and ongoing improvements to the component.
:information_source: Summary Add more groups to your Discourse /about page
:eyeglasses: Preview Theme Creator
:hammer_and_wrench: Repository https://github.com/discourse/discourse-add-groups-to-about-component/
:question: Install Guide How to install a theme or theme component
:open_book: New to Discourse Themes? Beginner’s guide to using Discourse Themes
Install this theme component
This component allows you to easily add more groups to the new /about page, more details on that redesign here: New and improved About page at /about is live
The component includes the following settings:
  • about groups: Groups to show on the about page, groups with 0 members are automatically hidden.
  • show initial members: Number of members to show on initial load for each group, others will be hidden behind a “show more” button.
  • capitalize names: Capitalize the names of the groups on the about page.
  • order additional groups: Alphabetically (default), by order of creation, or by order of the about groups setting — does not impact the order of existing admin and moderator groups
  • show group description: Shows the description of the group under the group’s heading (from the group settings)
19 לייקים
This is brilliant, thanks so much! :clap:
It would be possible to add a new setting to use the group full name? It would be nice to show unicode characters in it, but I don’t want to enable the unicode_usernames site setting.
5 לייקים
This is great, thank you @awesomerobot :smiley:
I’d second this motion.
I have a group called group-challenges-cmt which has a Full Name of Challenges Committee but they’re displayed on the /about page as group-challenges-cmt, which doesn’t look very nice :blush:
For reference, ticking the Capitalize the names of the groups on the about page option changes it from group-challenges-cmt to Group-Challenges-Cmt - is that right? Or should that checkbox only capitalise the first letter of the group name?
Strangely though, if I add group trust_level_4 to the about page, that shows up in the front end as Trust Level 4 :thinking:
This is great though, thank you so much Kirs @awesomerobot, I can now get rid of the JS code from all those years ago :smiley:
6 לייקים
Adding some visuals for reference.
Here’s how the group names look in the admin page:
And here’s how the group names look in the front end:
I don’t know how far you want to go with this theme @awesomerobot, are you taking feature requests? :smiley:
A way of ordering the groups would be great. I tried adding them in different orders in case it was database-id ordered, but it didn’t change anything so I assume it’s ordering them alphabetically.
Would it be possible to fix the alignment of the group members too?
You’ll the see the admins at the top of the page are three columns wide, yet the additional groups are all two columns wide? :thinking:
And once again:
:bowing_man:
4 לייקים
This looks great! Thanks, Kris. I find it to be a really sweet way to let people discover how the site is organized. Many groups on the site groups page don’t mean much and it is a cluttered place, vs the about page which can be a more curated destination.
I do wonder if we want to move this feature to core at some point. Collecting some feedback:
Feature has limitations as a theme component:
  • config UI not in /admin/config/about but in the theme component
  • does not respect about page hidden groups to exclude groups that should not be shown on the about page (ref)
  • styling (eg number of columns) of included groups is different from admin and moderator lists and would need to be updated every time we make a change to the the about page styling
There is some feedback shared already:
  • display group name not slug
  • auto capitalization doesn’t look right in some cases
  • add ability to order groups
I also think it would be helpful to provide a snapshot of more group metadata here, perhaps hidden behind an info button next to the group name?
  • description
  • group owner
  • group permissions
  • number of members in group
  • link to group page
3 לייקים
Either that, or make the group heading a clickable link to the group itself.
לייק 1
Some updates!
https://github.com/discourse/discourse-add-groups-to-about-component/pull/1
This requested happened faster then I expected :slight_smile: but I should have known.
The reason I didn’t do it initially is because I wanted to avoid an additional request… but I guess it’s unavoidable.
The way the theme component works, is that it matches the corresponding group ID from the theme setting to the site service (this.site.groups) — this contains the ID and the name, but not the full name…
Then the name gets plugged into the /g/${name}/members endpoint… which has the group members, but also does not have the full name…
So to get the full name, I need to make another request to /g/${name}.
The checkbox enables some simple CSS, text-transform: capitalize which capitalizes the first letter of each word.
Though I completely forgot about ::first-letter which I can use instead, so I’ve switched to that… this should be more consistent with our default capitalization now.
If anyone’s wondering, the reason to include this bit about capitalization is because automatic groups, like Trust Level groups, don’t have a full_name field and are always lowercase. What a tangled web we’ve weaved :sweat_smile:
I removed underscores in the component, but not dashes… this update will do both (but only for name, not full_name)
I’ve added a setting with the options:
  • alphabetical
  • order of creation
  • order of theme setting
Note this concerns the order of the additional groups, and won’t impact admins/moderators — which will always be shown first
Ah yes, there’s some CSS in Discourse that only applies to the moderator and admin groups, I’ve added a fix
Adding the description and link to group page are simple changes, I’ve added those (description disabled by default, but available in a setting).
Group owner is possible, but at the moment I reuse a core component AboutPageUsers — and that would need to be modified to be able to display the owner flair on the user avatar (which I think it probably the best place for it).
This component is growing in complexity fairly quickly, so I’m going to hold off on other requests until someone has a specific need for them.
5 לייקים
Very nice! It’s impressive what all you can achieve in a theme component.
I don’t know why people would include these groups.. maybe we can just ignore the capitaliation and allow them to be lower case.
I wonder if there have been requests in the past for full names for these groups - not sure why we don’t have it already.
3 לייקים
This is bonkers :rofl:
How do we go from a simple question a few days ago to a full blown theme that is absolutely perfect in every way?!??
Amazing, absolutely amazing :chefs_kiss:
Thank you Kris @awesomerobot :clap:t2: :bowing_man:t2:
5 לייקים
I think the most common case is showing Trust Level 4, because they gain some moderation powers
3 לייקים
Sure, I can see that. Trust level names and descriptions can’t be edited, though, so I’d suggest to those people that they create another group and include tl4 folks in it, and give it a nice name, flair and description that suits the community.
I did notice something weird about trust level groups on the about page - not every time I looked at it, but the group memberships were not showing up correctly. Sometimes I as admin am in tl0 even though I am in tl2 nominally. It’s also a bit weird that I show up there at all because I am admin so trust level is irrelevant. But that’s a idiosyncracy with discourse trust levels and how they work.
3 לייקים
I set up this for TL3. I’ve created a new group and with Discourse Automation I synced the Regular badge with the New TL3 group.
Yeah I noticed this too. First I hide admins with CSS but that break the layout a little bit so I removed the Regular badge instead as automation sync it for me. I am not sure if it’s will be added automatically later. Hopefully not. Yeah it automatically added again so CSS works now.
I’ve noticed also the group members order by descending in json. It would be nice to randomize it or set to by activity maybe ?order=last_posted_at or ?order=last_seen_at.
3 לייקים
That’s the very reason we do it on our community :blush:
Agreed.
I put a bit of CSS in place to hide our admin team members from the Trust Level 4 members that are displayed on our /about page.
This puts the spotlight on just those TL4 members, as they are to be thanked and congratulated for their contributions to our community:
I also found that trust level 4 was being displayed as Trust level 4 when ticked in the settings.
My OCD wasn’t happy about this because all the other groups had a capital letter at the start of each word :blush: I added another line of css to change Trust level 4 to Trust Level 4.
Everything is now as perfect as perfect can be.
Thank you once again @awesomerobot - we love it :chefs_kiss:
4 לייקים
Out of interest, how are all the members being ordered here?
Is it by user_id in the database?
3 לייקים
good question, looks like it’s actually ordered by username in reverse alphabetical order… which doesn’t make much sense, I’m going to add a little update that switches to alphabetical (which is the same as the member listing on the full group pages)
3 לייקים
I suspect re-ordering the admins is out of scope here :slight_smile:
Thanks Kris, this update seems to have re-ordered the Trust Level 4 user group but not the group below it? :thinking:
3 לייקים
The original about page groups like admins and moderators are ordered by last seen at.
I suggested here.
I think it would be good to use something similar to keep the original and custom groups order consistent. :thinking:
2 לייקים
They’re not consistent if they keep changing order though? :thinking:
This is a fantastic component. I think it could also be the basis of improving in part the group page. Adding collapsible headers to organize groups into categories.
2 לייקים
Currently running Discourse 3.5.0.beta1-dev (e26a1175d7) and the current latest version of this theme is installed.
Can I do a sanity check / bug check please?
Here are my settings:
You’ll see I have two groups added to the about page:
  • trust_level_4
  • group-challenges-cmt
The visibility of these groups is exhibiting some unexpected behaviour.
Admins can see both groups on the About page:
Non-admins can only see the trust_level_4 group on the About page:
Logged out users can not see any of the groups on the About page.
Before I head down any rabbit holes and wondering if something else is causing this issue (I’ve a lot of custom css in place), could someone do a sanity check for me please and confirm theirs is still working ok please?
לייק 1
